Old 02-21-2012, 10:12 PM   #1
Atommik
Atommik's Avatar
AD Truck, rear cab seam...
Very soon I will start doing the repairs on my 51, cab. The rears cab seam is in good shape, no rust holes. I'd like to get some opinions on wether to weld up the rear cab seam, or leave it as is. Anyone??
Atommik is offline   Reply With Quote
Old 02-22-2012, 08:33 PM   #2
nebdrummer
nebdrummer's Avatar
Re: AD Truck, rear cab seam...
I just did mine. Make sure you clean it out super good, and if possible, get a little spot blaster. then spray it down with some E-cote primer, then weld over top. Take lots of time in tiny spots to minimize warpage.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 02-22-2012, 10:22 PM   #3
D-man313
D-man313's Avatar
I didnt weld mine, but cleaned it out real good, and seam sealed it.
http://solutions.3m.com/wps/portal/3...glNSHDL7F927bl
Didnt buy it online tho, found at local auto parts store.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 02-22-2012, 11:27 PM   #4
nebdrummer
nebdrummer's Avatar
I thought about seam sealing it too, which might work just fine. I just had no clue how much body movement these old things have, so I figured instead of the possibility of repainting down the road, I'll just take care of it now.
How long has yours been painted D-man?
Old 02-23-2012, 06:59 PM   #5
D-man313
D-man313's Avatar
since about August 2011
Old 02-25-2012, 01:41 PM   #6
Chevette
Chevette's Avatar
A friend of mine used Fusor on his rear cab seam and it worked excellent. No heat, no warping and it's as strong as a weld. I used it one time to attach dissimilar metals on a project. You can read up on it here.
http://www.lord.com/Products-And-Sol...r-Products.xml
Chevette is offline   Reply With Quote
