02-21-2012, 10:33 PM | #1 |
auto Column that uses cable to shift?
auto Column that uses cable to shift? Is there such a thing?
I have a ratchet floor shifter. I don't care much for it. It uses a cable to shift the trans, Is there a streering column that I can use that can use a cable to shift automatic trans?: |
02-21-2012, 11:26 PM | #2 |
Re: auto Column that uses cable to shift?
uhm...
You might want to include what year truck you have, chevy or gmc... long or short bed and what kinda engine and transmission... then maybe the folks in here can narrow it down for you. -W |
02-21-2012, 11:46 PM | #3 |
later model trucks and tahoes use cable 1996 or so and newer but they have the key in the column
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
02-22-2012, 01:20 AM | #4 |
02-22-2012, 11:57 AM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
I would go with the locar, also you can pick up a 71/72 tilt column from CPP, that is really reasonable.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-22-2012, 07:34 PM | #6 |
Thanks to all of you, I looked at the lokar site and it looks like you are pointing me in the right direction. I looked for CCP? site and could not find I will look until I find it. Thanks again. I will post pictures of my truck when I figure how to post them until I do you really are not missing much as far as looks, It will get better soon. Its ugly but dang it is a sweet runner.
I have a 1962 chev fleetside short bed, running a 454 motor and a 400 trans with a ford nine inch rear. |
02-22-2012, 07:44 PM | #7 |
lokar set up work really well done 20 of them.
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
02-22-2012, 08:12 PM | #8 |
Thanks Rayday
any sugdgestions on sterring columns to use? It has the old 62 still there. I don't think the key in the column would bother me not an original guy just want it nice and neet. |
02-22-2012, 09:43 PM | #9 |
flaming river , ididit, all good basically just copy's of late 70's gm stuff. I use g body (malibu/monty/grand prix/ect) 78-84ish a few times they are simple, clean. And every thing after market like u joints shift levers fit them, and they don't have wiper controls on turn lever. also truck tilts seam to fetch huge $$$$ were car tilts not so much? i don't know why? Car columns fit well. A little more work than bolt in, but simple stuff. plus i get them for around $40 ea.
