Old 02-21-2012, 10:55 PM   #1
texasbigbear_wink
texasbigbear_wink's Avatar
Air Bag Helpers on axle flip?
Has anyone did this? If so do you have pic's/info on what you did?
Thanks BEAR
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 02-24-2012, 11:45 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Bag Helpers on axle flip?
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-24-2012, 12:37 PM   #3
andrewmp6
My only thought is mount it on the outside of the frame but that depends on if your tires will hit it or not.
andrewmp6 is offline   Reply With Quote
Old 02-24-2012, 05:34 PM   #4
Cherub
Cherub's Avatar
Are you talking about a flipkit then putting on a AOL setup? If so Yes i did it on my suburban. you just have to watch out for the shock mounts cause they will get in the way.
Cherub is offline   Reply With Quote
Old 02-24-2012, 07:32 PM   #5
rwhit57
rwhit57's Avatar
Did you buy a kit? I'm interested in this also. I haul some stuff and now may do some towing with my truck. I have seen it done on one tons. Anyone know the best kit? I also thought about just regular air shocks but from what I remember they can be really rough riding.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-24-2012, 07:38 PM   #6
SBTork
Garage wrench
SBTork's Avatar
http://www.ridetech.com/store/airoverleaf/
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-24-2012, 08:52 PM   #7
badchevy
Here is a pic of where I mounted my bags. They are toward the front. I believe these bags are for a '05 GM truck. They work good and haven't had any problems. I have to have them aired up in order to keep the back end level. I'm running a flip kit with four leafs (two centers are not arched). I'm running a Belltech notch with a button bump stop. If I don't have air in the bags, the axle sits on the bump stop.
FYI, I'm running 15x8s with 275/60 tires.
badchevy is offline   Reply With Quote
Old 02-24-2012, 09:37 PM   #8
rwhit57
rwhit57's Avatar
Badchevy, Nice truck! So is the bag sitting on the leaf spring with like a saddle clamp and the top bolted to the frame? Do you run an onboard compressor? Would you have to or could you just air them up with a schrader valve? Sorry about all the questions. OP is gonna have plenty of info. Thanks
Old 02-24-2012, 09:53 PM   #9
gGMC DOG
how much drop do you have and what size notch is it?
gGMC DOG is offline   Reply With Quote
Old 02-25-2012, 11:27 AM   #10
blazer2007
The bags look like they are quite abit forward on the leaf,no problem?
blazer2007 is offline   Reply With Quote
Old 02-25-2012, 12:57 PM   #11
badchevy
The bag is sitting on the leaf spring is held in place with a fabbed clamp I did. It's just to keep the bag in place. As for the top, yes, it's just bolted to the frame. I'm running a small portable compressor (similar to the ones sold at parts stores) to air up my air tank for my air horn but also serves to air up my bags via a schrader valve. Pretty easy setup. And I haven't had any problems yet. Yes, they are a little forward in the leafs but there is not too many places to mount them with the flip kit. Might try something different later but they'll work for now. Hope this helps others.
Old 02-25-2012, 01:00 PM   #12
badchevy
I have roughly a 5 1/2 to 6 inch drop up front (3" drop spindles, lowered springs) and a flip kit with straightened out leafs out back. The notch is a Belltech c-notch with a button type bump stop. I have to keep air in my bags in order to lift it a little. If not, the axle will bottom out.
Old 03-28-2012, 08:51 PM   #13
texasbigbear_wink
Thanks For the info guys. I have Ben working my A** off so have not had much time to get back on. But this is what I have dun to the truck. I made the axle flip kit in my fab shop and installed it, this put me about 3 inches from the frame to top of axle and installed 3 inch drop spindles with stock springs. My problem now is that the front is higher than the back even with the 3 inch drop, so i am thinking the leaf springs are slapt out but think I would like to lower the front to level it rather that new leaf springs in back. So I will be installing drop springs in the front soon and hope that air bag helpers for the back will keep me from further mods to the back and level the truck out.
87 Chevy R10 LB
Old 03-28-2012, 08:56 PM   #14
texasbigbear_wink
This is a video of it with the new exhaust installed and one of its first runs.
87 Chevy R10 LB
