Noob here!
Just wanted to say "Hi" to y'all and say I'm a noobie to the forum. I've been perusing the site for months now. Last month I finally got my 68 LWB home:
![]() Not a bad buy for $900! It runs like a champ (PO put a mild cam and a Edelbrock 650 on the 307) and its my DD for now. It'll be a rolling project. I've already taken the 69 hood off and put the original 68 hood back on. Has some rust issues here and there, but I'm not complaining. Shifting (its a 3 on the tree) is interesting, but I think it just needs to be adjusted. Future plans: power steering, disc brakes, 3/5 drop (I'd go more but I want to be able to haul stuff in the back), and a matte black paint job. Does anyone know if the steelies on there will work with disc brakes? Thanks in advance for all the help and advice I've received and will receive! |
Re: Noob here!
I went with a 3/5 drop and I'm pretty limited on what i can haul, 1/2 yard of top soil was the absolute max. I do have 275/60/15's on the back though so that probably doesn't help. Saying that I love the look and don't care!
Re: Noob here!
IRN BRU,
thanks for the heads up. I'm mostly concerned with hauling a motorcycle and generator at the same time. I don't think I'll ever need to haul REALLY heavy stuff. But if I start bottoming out I'll put some airbags in the back to help the springs. Could you post a pic of what your truck looks like with the 3/5? Most of the pics I've seen don't have anything for reference to the truck. Its just the truck by itself...so its hard to tell how low its actually sitting. |
The Older Generation
Re: Noob here!
On the shifter, put the lever in neutral (apply parking brake or block wheels first) and spray some PB Blaster or some other penetrating oil (not WD-40) into the hole that the shift lever goes into on the column. Then pull the lever up toward you and push it back down 4 or 5 times to loosen it up. The lever has to move up and down easily to shift gears. After you have done that spray the tube and levers good at the bottom of the steering column then go in and pull the lever up and down again. See if that makes a difference. A lot of people that are not used to the older 3 speed trannys don't realize that you have to pull the shift lever up toward you for low and reverse and push down when shifting into 2nd and 3rd.... If that doesn't work try this... http://67-72chevytrucks.com/vboard/s...d.php?t=215307 Then report back... ![]() Oh, and ![]() Lockdoc
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Noob here!
Welcome from Central Florida! Air shocks on the rear might solve your future towing problem.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: Noob here!
Hey from N.C.Nice truck & it looks like you have something to work with,& welcome to the best truck site they are.Hope to see more pictures soon & keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
![]() Join Date: Jan 2006
Re: Noob here!
Colorado says
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
![]() Join Date: Feb 2001
Re: Noob here!
Hey munky ...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: Noob here!
Hope this helps! 3/5 drop
#10 | ||
Re: Noob here!
Thanks! That's a lot lower than I thought!!! |
Re: Noob here!
Here's how she sits now, after several coats of paint and a pair of cut coils
Re: Noob here!
Still need to convert it over to power steering, do the disc brake conversion (anyone know if those wheels will fit disc brakes?), and lower the rear.
I'm happy with Ol' Dirty ![]() |
#13 |
![]() Join Date: Nov 2007
Re: Noob here!
That looks great, nice job.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#14 |
Re: Noob here!
Good job.
#15 |
Re: Noob here!
Are you sure the shiftier linkage is not loose? I had to help an old guy push his truck out of his yard and the shiftier was so loose it jammed in between gears.
this might help http://67-72chevytrucks.com/vboard/s...d.php?t=462039
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
