Old 02-22-2012, 07:48 AM   #1
birdman 67
64 chevy c 10
Just wondering if anyone has had a problem with there front rotors rubbing on there A arms.Did a disc brake conversion and now my A arms touch the rotors any solutions out there.
birdman 67 is offline   Reply With Quote
Old 02-22-2012, 07:59 AM   #2
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 64 chevy c 10
Just grind the end of the A arm 'til it's not rubbing.
Unless of course it's flat out not fitting.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-22-2012, 10:12 PM   #3
birdman 67
Re: 64 chevy c 10
thanks for the reply not too sure if I'm allowed it's got to pass an out of province inspection.I will phone and ask. I was also told to put spacers.
Old 02-23-2012, 07:26 AM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 64 chevy c 10
How much material do you think you'd have to remove??
If you take too much,you risk the integrity of the ball joint support.
What spindle are you running?
What A arms?
Is it lowered?
I've never heard of "spacing"..?...anything tapered needs to be fully seated and moving the rotor outward is going to affect caliper function.
If the grinding is done "tastefully",i.e. maintaining the radius on the lip of the A arm,you'd be hard pressed to find a mechanic that will notice as there are no "specifications" in this area.
Not sure who you're going to call,but I think your best answer will come from the folks here.
I'm sure more people will chime in....if not,have a Moderator move it to the suspension section.
BTW,Welcome to the addiction
Trent
member#7816
'61 GMC in progress
Old 02-23-2012, 02:48 PM   #5
steveb64
steveb64's Avatar
Re: 64 chevy c 10
Had the same problem a while back with mine. I have the CPP modular drop spindles. I began pursuing it with CPP but ended up just grinding my lower arm. I suspected that the drop spindles were machined incorrectly and allowed the hub to be to far inboard. As I said, I started to pursue this with CPP but saw that it was going to cost me more with shipping back and forth, I was going to be the real financial loser in the whole mess.
I did not want to do it, but the grinding did work and I don't think I compromised the strength of the lower arm.
As a side note, I noticed that something might be wrong when I went to install the rotor and the castle nut went on so far that the whole for the cotter pin in the spindle did not engage the nut. I added some washers to bring the nut out on the spindle so the cotter pin would engage.
Not what I like but I settled for this arrangement for now.
steveb64 is offline   Reply With Quote
Old 02-23-2012, 08:24 PM   #6
birdman 67
Re: 64 chevy c 10
Thanks for the info looks like im gonna have to do some grinding
Old 02-23-2012, 11:41 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 64 chevy c 10
Is there a chance those spindles with designed to use the 1" rotor instead of the 1.25" rotor? I don't know that the two rotors will even fit on the same spindle, but that sure doesn't seem like a correct fit.
Old 02-24-2012, 12:25 AM   #8
Rich 5150 69
Rich 5150 69's Avatar
Re: 64 chevy c 10
If you check the discbrake thread, it says to use the c-20 lower a-arms with the modular spindles, there must be a differance.......
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-24-2012, 08:59 AM   #9
birdman 67
Re: 64 chevy c 10
I got the kit from performance online and from what I've read from people on here so far is that the reproduction stuff doesn't always fit like it should.
Old 02-24-2012, 01:53 PM   #10
steveb64
steveb64's Avatar
Re: 64 chevy c 10
Good to know. Late, but good to know.
I would think the vendor (CPP) would know this and let the customer (me) know when he orders the parts.
Oh well, live and learn and bendover.
Old 02-24-2012, 02:57 PM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 64 chevy c 10
I have installed two sets of these CPP modular spindles without a single problem. Both use the 1 1/4" thick rotor on 1/2 ton lower a-arms. No rubbing issues, castle nuts lines up correctly.
It does seem that they are using the '73 and later ball joints and tie rods, regardless of application. My '65 truck had '73+ spindles/brakes already so I just swapped the modular spindles in place. Nothing changed. The '65 panel, doing the full conversion, it came with new '73+ ball joints and outer tie rod ends. An adapter tie rod sleave and '63-'70 inner tie rods to use the original center link.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-24-2012, 03:01 PM   #12
chevy_mike
chevy_mike's Avatar
Re: 64 chevy c 10
I believe this is if you want to use '88-'98 spindles. You need to use a C20 lower arm as these spindles use a 3/4 ton size lower ball joint, which will not fit into the 1/2 ton arm. By using this generation of spindles, you can use all factory GM parts and have either factory 5 or 6 lug rotors. I thought about doing this and even had a set of spindles but since I wanted dropped spindles and would have to buy them anyways, I just bought one for the 1/2 ton arms.
