Old 02-22-2012, 10:59 AM   #1
scott72
scott72's Avatar
Reinstalling Headlight Switch Knob
Is there any trick to get this back in?
There is a notch on the end of the knob, but it isn't catching on anything. Not sure if I broke anything off, or pushed the mechanism inside back in too far. It pushed it back to where the park lights are on, but the headlights are off now.
scott72 is offline   Reply With Quote
Old 02-22-2012, 11:27 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Reinstalling Headlight Switch Knob
I guess my first question would be how did you get it out. Did you just pull it out? You might try turning the knob one way or the other as you "Gently" push on it.
LockDoc
Leon
Old 02-22-2012, 11:41 AM   #3
scott72
scott72's Avatar
I pushed the button in on the back, to get it out originally. It didn't seem like anything broke. It came out fairly easy at the time.
Old 02-22-2012, 11:54 AM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You need to push the knob all of the way in. Once you think the know bottoms out, the spring tab inside the switch should push up with the end of the knob then lock in place. If not you may have broken the switch. Do you have an aftermarket knob? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-22-2012, 12:01 PM   #5
LockDoc
LockDoc's Avatar
That would be correct. You might try putting a little lube on the pointed end of the shaft.
LockDoc
Leon
Old 02-22-2012, 12:02 PM   #6
scott72
scott72's Avatar
I think it is the original, but not positive. Yeah, when it bottoms out, nothing latches onto it.
Old 02-22-2012, 12:48 PM   #7
Classic Heartbeat
It can't hurt to try LockDoc's remidy first, but if it doesn't work you need a new switch. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-22-2012, 03:24 PM   #8
68gmsee
Active Member
68gmsee's Avatar
I think it's the spring that breaks or sticks. You could try taking it off an spraying some WD in there. It might also help to clean the sliding contacts in it also. If that doesn't do it, local auto parts carry the switches.
68gmsee is offline   Reply With Quote
Old 02-22-2012, 05:23 PM   #9
Autoblueprint
Autoblueprint's Avatar
Post Re: Reinstalling Headlight Switch Knob
Sometimes the release button on the headlight switch sticks in the down position. Try holding the button down, then push the rod in and then wiggle the release button till it pops into the out position.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 02-22-2012, 09:03 PM   #10
Sammy
I have had a few do this. All the lub of WD didn't help them. Ended up replacing the switch. Took one apart also didn't notice anything broken or worn out. Now it's in a can some in the garage somewhere.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-26-2012, 07:47 PM   #11
scott72
scott72's Avatar
The PO had some kind of makeshift nut to hold the switch in. I do not think it was the correct size. It did not allow the knob to seat all the way in and latch itself.
Anyone know what the correct one looks like? Does lmc carry them? I couldn't find it on classicparts.
Old 02-26-2012, 07:50 PM   #12
LockDoc
LockDoc's Avatar
PM me your name & address and I will send you one...
LockDoc
Leon
Old 02-26-2012, 08:25 PM   #13
scott72
scott72's Avatar
Thanks. Here is what was attached to it.
I am guessing this is not correct, because it doesn't latch with this on there.
Old 02-26-2012, 08:49 PM   #14
LockDoc
LockDoc's Avatar
Yep, that is the correct one. That is the same as the one I have. Sometimes they are hard to screw in but you have to make sure it is screwed in all the way and that the small tang on the front of the switch is in the notch in the dash... The chrome bezel screws onto the short end of that.
LockDoc
Leon
Old 02-26-2012, 10:01 PM   #15
scott72
scott72's Avatar
I finally figured it out. It seems like the mechanism needs to be in the on (pulled out) position. Then barely slide the knob back in and it clicks.
Old 02-27-2012, 12:04 AM   #16
LockDoc
LockDoc's Avatar
Glad you got it sorted out.... "On The Road Again"..
LockDoc
Leon
