Old 02-22-2012, 11:25 AM   #1
ryanmctee
ryanmctee's Avatar
Adding Upper Trim
Looking for measurments from lower trim holes to the upper ones. Somebody's got to have them. My truck currently does not have upper trim, and I thought whats an easier way to figure out the location of the upper trim than taking the distance from the lower to the upper? Help would be greatly appreciated as I'm getting very close to paint and really need that upper trim location for the paint line.
Picture isn't my truck, just a visual explanation of what I'm looking for.
Thanks all!!!!!!!!!!!!!!!!
ryanmctee is offline   Reply With Quote
Old 02-22-2012, 01:48 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Adding Upper Trim
I don't think I would use the location of the lower trim as a measuring point. I have seen some lower factory trim installed right on the body line, right under the body line and up to 1/4 inch below the dody line.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-22-2012, 02:18 PM   #3
Dano69c10
Dano69c10's Avatar
Maybe get the measurement from the body line to the upper moulding.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-22-2012, 02:34 PM   #4
MrGoodpliers
MrGoodpliers's Avatar
I agree that some factory equipped trucks have the trim all over the place, namely the front fender trim seeming to go uphill towards the front. When I installed upper and lower trim on a truck that was not originally equipped, here's how I did it: Install the door trim level with the lower bodyline and with the lock in place. Then install the cab corner. For the bed and fender trim, tape them in place and move the outer ends down until pleasing to your eye. If you install the trim dead straight with the door trim it will not look good. From the side it will appear that the ends are high.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-22-2012, 03:54 PM   #5
cjohnson6772
cjohnson6772's Avatar
click this
cjohnson6772 is offline   Reply With Quote
Old 02-22-2012, 04:18 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by cjohnson6772 View Post
beat me to it. Thanks for posting that!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-22-2012, 04:19 PM   #7
cjohnson6772
not a problem. that one is saved on my hard drive so i knew exactly where to find that info.
