Old 02-22-2012, 02:50 PM   #1
MilkyJoe
MilkyJoe's Avatar
Looking for lift options for my 10
Hey all.
I bought this truck with intentions of using it for towing and for pulling things in the fields.
My truck leans to the right,it hangs about 2 inches lower.
My dad said the leaf bushings on the front driver side will cause that, but the rear drivers side is lower too.
I think this may be why the truck likes to wander when driving and braking
not to mention when towing
I have about $550 to play with and was wondering if a solid 2-3 inch spring lift would be good. I just want the truck to sit level and be a little taller because the tcase sits a little low. it is an old canadian city work truck so there is a lot of rust.
I don't need it to be tall, it is sitting on new 32x11.50s
MilkyJoe is offline   Reply With Quote
Old 02-22-2012, 02:56 PM   #2
MilkyJoe
MilkyJoe's Avatar
Re: Looking for lift options for my 10
I searched, but nothing was helppful.
I need a lift that willl level her out, but also still handle well when towing/ hauling.
Old 02-25-2012, 04:23 AM   #3
rpatowers
I had the same problem with my truck. First I replaced all of the body bushings. Some were missing completely, others were way broken down. that leveled it nicely. Then I put in a 4" spring lift. All is well now.
rpatowers is offline   Reply With Quote
Old 02-29-2012, 04:09 PM   #4
Deaol
When I had my ol' 83 k10 I did the shackle flip in the rear (4") and a 4" spring up front (ez ride tuff country). all in all it was about $400 and an afternoon to install it. Keep in mind mine already had a 4" block lift (that was eliminated with the use of the shackle flip) in the rear and old sagged out front lift springs. My shocks were still decent. You can get really good deals on procomp/bds 2-4" lift shock kits on ebay for around $30 a corner. Your also going to want to get a raised steering arm ($50-60) if you got the 4" route. Lengthened brake lines might be needed as well.. stainless braided is the way to go.
Few good links : offroaddesign.com / diy4x.com
* 1968 GMC Swb - 98% done (current restoration)
* 1971 Chevy Lwb - Retired Dump Hauler
* 1982 K10 Longbox - New Dump Hauler
Deaol is offline   Reply With Quote
Old 03-03-2012, 01:16 AM   #5
rpatowers
My truck used to lean quite a bit. I thought the frame was bent from an old accident. I paid a guy $1200 to straighten the frame. When he'd finished it still leaned. Then he put a spacer of some kind under one corner of the bed -the lean was then quite grotesque. Finaly I looked at the bushings and saw they were broken down/missing completely. I removed his bed spacer and installed new bushings and all was well.
Now comes the question: Was the frame bent in the first place and what did the guy do for $1200 (actually two questions)?
I'm the guy he saw coming.
Old 03-03-2012, 04:53 PM   #6
84chevy4x4
84chevy4x4's Avatar
it looks like the lean could be caused from a rotted rad support or the body mount below it. if you look at the 2nd picture you can see the line between the bumper and the rad support
1984 Chevy K20 work in progress
1977 Chevy C30 Dump
1979 GMC 35 4x4 Dump
1969 GMC 1500 Rat
84chevy4x4 is offline   Reply With Quote
