Old 02-22-2012, 03:47 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation 1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
BOLT-IN FRONT STEER IFS
'60-87 GM/GMC Pickups -- A total bolt-in package
http://www.jimmeyerracing.com/pu6.html
Using stock-existing factory holes, this easy-to-install, bolt-in or weld-in IFS kit featuring ‘78-88 front-steer Impala spindles, 12-inch diameter (Impala) rotors, calipers, and balljoints will give you a 5-on-5-inch diameter bolt pattern. The stock crossmember will unbolt and is replaced with a new 2 x 4 x .188-inch wall bolt-in crossmember that holds a ’83-87 T-Bird power rack-and-pinion steering unit. Either a stock, power GM gear-box pump or GM rack pump is compatible to operate the rack. C-channel frame stiffeners, that bolt inside the frame, are also included in the kit. Modifications to the bottom of the steering column will be necessary to connect to the rack spline, or replace it with an ididit column.
The stock 64 1/2-inch front track width is narrowed to 62 1/2-inches with the new IFS kit. The kit features D.O.M. tubing upper-and-lower A-arms (1 1/4-inch dia. X .156-inch wall lower arms and a 1-inch dia. X .156-inch wall upper arm). The aluminum, adjustable coilover shocks with powder coated springs are attached to a three-position upper mount and a two-position lower mount that offers you about 4-inches of movement for the stance you like best!
Dropped spindles, custom track widths, 1-inch diameter sway bar, steering linkage kit and column are just part of the options available.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-22-2012, 04:20 PM   #2
darkhorse970
darkhorse970's Avatar
Re: 1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
I've wondered how that would work out. Ride height, handling, weight, adjustability...
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-22-2012, 05:51 PM   #3
MailManX2
MailManX2's Avatar
I have this kit for my 60 Apache but haven't gotten it installed yet. The kit that's shown is actually for 63-87 trucks. For the 60-62 frames a plate has to be welded over the big holes on the inner frame and then the motor mounts get welded to that. Also because of the frame differences the doubler plate is not included.
Aside from items I mentioned I think the rest of the kit is the same as pictured in the Jim Meyer photo. The workmanship looks to be top knotch.
I did do a test fit on my frame when I got the kit. Fit was good.
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 02-22-2012, 06:14 PM   #4
creep
Registered Loser
creep's Avatar
Yet another nice front kit for our trucks. I like how the upper balljoint plate is welded inside slots in the A-arm tubes. Nice clean look thats also very strong. The upper arms from the kit I used are built the same way.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-23-2012, 01:51 AM   #5
Clownpuncher
Clownpuncher's Avatar
Jimmy builds some good stuff. I had their products on a '49 F1 I had. I really like that you can move the upper shock mount to gain a little more travel when lowered..
Chuck D
66 C10 LS6/4L65e
Clownpuncher is offline   Reply With Quote
Old 02-23-2012, 02:08 AM   #6
shawno72
C/10 junkie
shawno72's Avatar
How much are their base kits?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-23-2012, 11:55 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
The kit looks great. Personally I would use one of our Forum Vendors kits first.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-23-2012, 01:26 PM   #8
hopped up
hopped up's Avatar
im sure its not inexpensive, but then again its an entire front suspension upgrade. im sure its too much for me
hopped up is offline   Reply With Quote
Old 02-23-2012, 02:39 PM   #9
argonaut
argonaut's Avatar
The fabrication looks nice, but I'm always critical of these suspension kits. I always like to talk to the engineers/fabricators who designed them before dropping a bunch of cash.
I wonder how the actual geometry of the suspension, through the range of motion, compare to the factory suspension?
I don't really like the use of heim joints on the upper control arm instead of bushing. The inherent geometry of the upper arm constrains it to only rotate about a single axis. I do realize that they are probably installed to allow for changes in camber, however their orientation is not really correct, as the mounting point will be closer together or further apart as you adjust them in and out. In my experience building cars heim joints are too harsh for street use and fatigue too quickly, especially on a heavy vehicle like a truck. A bushing would be better. Plus don't out 60-66 trucks already use solid bushings form the factory? And aren't they greasable, unlike these?
I would like it better if the mounting point of the upper control arm to the crossmember was adjustable too; In-out and up-down. As you change static ride height with the coilover mount you will also drastically change the static and dynamic suspension geometry. Often times you want to be able to move the pivot point of the upper control arm down and in toward the center of the vehicle to lower the roll center and also to ensure that you don't increase positive caster as the suspension compresses, or that the rate of camber change isn't too aggressive.
Sorry to be critical, but I think its always good to ask questions and know what you are buying before you buy it. I'm not saying it isn't a great piece, its just my engineering nature to question.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-26-2012, 07:43 PM   #10
MailManX2
MailManX2's Avatar
I purchased this kit a few years ago and at that time I don't think any of the forum vendors were making front suspension kits for the 60-66 Chevy trucks. The only 2 I knew of at that time were Jim Meyer and FatMan Fabrication.
Ken B
60 Chevy Apache
Old 02-09-2013, 06:55 PM   #11
1Bad62Pro/Street
Arrow Re: 1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
Bump for 66-PMD-GMC.
Old 02-01-2014, 09:03 PM   #12
Layrokr
Layrokr's Avatar
Help! I bought this kit new uninstalled. I can't seem to get the steering u joints to line up from rack to stock steering column location. There doesn't seem to be room to mount a hiem joint. Anyone installed one of these with pics. and a fix.?
Layrokr is offline   Reply With Quote
Old 02-01-2014, 09:06 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
Neat kit!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-12-2014, 07:07 AM   #14
luvbowties
luvbowties's Avatar
Thumbs up Re: 1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
A phone call should answer all your ????'s. HTH,
Sam
>> http://www.jimmeyerracing.com <<
luvbowties is offline   Reply With Quote
