02-22-2012, 08:53 PM | #1 |
C10 addict
Speed warning brass pin removal?
Has anyone pulled one out before? If so, could you educate me on how to accomplish this? I don't want to damage it and I'm not sure how it installs, but it looks like it has a swagged washer? Any help is appreciated!
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
02-23-2012, 12:35 PM | #2 |
Restoration Virgin!
Re: Speed warning brass pin removal?
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
03-06-2012, 01:36 PM | #3 |
C10 addict
ttt
03-06-2012, 03:13 PM | #4 |
Yep, its swagged, with two isolater washers in between. You would have to cut the brass washer to remove it. Then build another washer and swagging tool with four jaws to make it oringinal....why does yours have to come off
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-09-2012 at 11:42 PM. |
03-08-2012, 12:17 PM | #5 |
C10 addict
That's what I figured, the tin was cut by the PO to install a factory tach but he cut the hole too low so the tach doesn't look right so I wanted to start over with a different tin but it doesn't sound like that's an option if I want to use the brass pin for the speed warning.
03-08-2012, 02:11 PM | #6 | ||
Always on the hunt...
03-08-2012, 02:24 PM | #7 |
C10 addict
Yep, Wes supplied me the other tin and I had him ship it directly to Les to cut the hole for the tach. I started this thread before we worked out those details. Les finished it up today and shipped it to me. Wes has been great about this whole thing and I will definitely do more business with him in the future!
03-09-2012, 11:27 PM | #8 | |
03-09-2012, 11:42 PM | #9 |
Mel, im sure your right about that pin, i was just passing on info. I got from someone with out confirming it or possibly misunderstood them.
Thanks for catching my miscue...... Why would GM isolate with plastic spacers if it is just a ground, dunno
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-10-2012 at 01:02 AM. |
03-10-2012, 02:05 PM | #10 | |
I am slmost 100% sure that if 12 volts were added to that pin, the S/W head or atleast some of the contact parts of it would fry when the two needles came in line with with one another. I am thinking if you had 12V.to that rear pin and your S/W needle set @ 88, this old movie quote comes into mind: "If my calculations are correct, when this baby hits 88 miles per hour, you're gonna see some serious chit." Mel |
03-10-2012, 04:05 PM | #11 |
If you ever break one of the plastic screws that holds the speedo face on, do not replace it with a metal scew or the hole speedo head will be grounded and the buzzer will buzz continuosly
03-10-2012, 07:11 PM | #12 |
Great info guys, and thank you for your help
Just found out why you cant adjust the needle below 21mph, the adjusting gear has no teeth cut in it below that area. A little 3in 1 oil on the gears and it operates much smoother
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-10-2012 at 07:17 PM. |
03-10-2012, 08:02 PM | #13 |
"brand new second-hand"
Thanks-I always wondered why the gauge has plastic screws
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
03-10-2012, 11:43 PM | #14 |
C10 addict
I bought 1000 of those nylon screws a long time ago to replace some that the heads sheared off so if anyone needs any I'll send you some if you cover the envelope and postage
