Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-22-2012, 09:09 PM   #1
Baged72
Baged72's Avatar
Welder/Electircal Question
Sooo... my shop at my house is wired for 220v but it has a dryer plug so im guessing its only good for 30 amps i was told? can i never use a 220v welder?
I just purchased a hobart 190 and it says it does 29amps to 190 amps???
I was really hoping to use a 220v welder as i have 220v plugs everywhere.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 02-22-2012, 09:44 PM   #2
donut
donut's Avatar
Re: Welder/Electircal Question
Check on the current pull of the welder, not the output. I don't remember the draw of my old Lincoln, you should have a spec sheet somewhere.
I do know my air compressor is 15a. (3hp 60gal.)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-22-2012, 10:31 PM   #3
Baged72
Baged72's Avatar
I just went to Hobarts website the 190 draws 230volts @ 20.5 amps so.... does this mean 20.5 max?? or on average??
Im just afraid to plug it in and it not work then i cant return it. It wasn't that cheap.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 02-22-2012, 10:34 PM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
Website says at rated output that welder requires 20.5 amps @ 230V.
http://www.hobartwelders.com/product...ed/handler190/
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 02-22-2012, 11:27 PM   #5
Notch1988
Notch1988's Avatar
I run my 180 miller off 30 amp outlets with no issues. Just make sure it is a 30 amp breaker servicing the outlet.
Notch1988 is offline   Reply With Quote
Old 02-23-2012, 12:59 AM   #6
SoCalK20
You'll probably have to either change out welder plug or wall receptacle to work. Dryer outlet are usually 30A. with #10 wires. make sure you have 2 hots and a ground. Welder usually comes with 50A. plug so I change out 30A. dryer for a 50A. welder receptacle. You wouldn't normally have a 50A. plug with #10 wires. In new construction or remodel of shop or garage, you would run #8 wires to receptacle. Code allows use of existing 30A. circuit for welder. If you change out receptacle, just label it. Good luck
SoCalK20 is offline   Reply With Quote
Old 02-23-2012, 01:01 AM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
You'll be fine. Plug it in and start welding.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 02-23-2012, 09:35 AM   #8
yousesteers
It will work what is the guage of wire and the rating on the breaker for that circuit I would do it the worse you could do is flip the breaker
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 02-24-2012, 06:10 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've never seen a 220 breaker rated under 30 amps though I'm sure they make them.Almost all other countries use 220 instead of 110-120.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-24-2012, 06:34 PM   #10
yousesteers
Europe uses 110 but it is at 50hz instead of 60hz and our items will not work over there even though same voltage
Clint Youse
Paris, MO
Old 02-28-2012, 09:33 PM   #11
Dustytrix
Yes you can buy a double pole 20 amp breaker. If you decide to weld with only 30 amp wiring to you shop, make sure everything else in the shop is off, except maybe lights.
Dustytrix is offline   Reply With Quote
Old 03-01-2012, 08:22 AM   #12
cdowns
cdowns's Avatar
i'd run a new dedicated outlet with the heaviest gauge wire so as to maintain a good supply when you need to use welder run on an extension cord to b closer to your work
Old 04-05-2012, 05:36 PM   #13
DesertCat
DesertCat's Avatar
Sorry, but that is wrong. Europe is entirely 220v 50hz.
Just to set that straight....
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 04-12-2012, 08:38 PM   #14
MadManAndrew
I just tied into the dryer breaker and put a welder plug where I was going to put my welder. Works fine.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 04-20-2012, 03:04 AM   #15
Sub-versive
Boss Hogg
Sub-versive's Avatar
Wisdom.
This is best.
If you use your dryer outlet, check things out. Make sure it's at least #10AWG copper wire, 30Amp breaker, and everything looks in good shape. And don't run extension cords off it.
If you need extension cords, run larger wire, like #6AWG copper.
RIP El Jay
2015 Subaru Outback 3.6R Limited
2002 Chevy Trailblazer LS 2WD
Originally Posted by dammitmitchell View Post
....wear your adult diaper when you go out to play.
Originally Posted by Shane View Post
I am tard.
Do, or do not, there is no try
Sub-versive is offline   Reply With Quote
Old 04-24-2012, 12:30 PM   #16
ozzyman
ozzyman's Avatar
Ran my Mig Welder off of #6awg copper to a 50amp outlet from a 2 pole 50 amp breaker. Total cost for 15' of wire, outlet, cover(outside), box and conduit since the line is wired outside ran me around $80 at home depot. I should be able to safely run an extension cord if needed.
Check lowes and home depot for discounted end of roll cable, sometimes you just might find what you need for cheap
ozzyman is offline   Reply With Quote
