02-22-2012, 09:25 PM | #1 |
Tach not working correctly after removing gauges
I removed my gauges and cleaned them resembled the gauges. I checked to make sure it is getting 12v. The tach worked before I took it apart. I works now but not accurately before it shows 200rpm but before when it worked it was reading 600rpm. So could the gauge have just crapped out and not reading correctly? I have checked all connection. Any input would be greatly appricated
Posted via Mobile Device |
02-22-2012, 09:34 PM | #2 |
Re: Tach not working correctly after removing gauges
Wish I could help. I have the same problem, but with an aftermarket gauge. subscribed for answers.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
02-22-2012, 09:41 PM | #3 |
Check the grounds. Did the tach needle fall off or get bumped out of position?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 02-22-2012 at 09:41 PM. Reason: Ipad auto correct correction |
02-22-2012, 09:56 PM | #4 |
No I don't think it did.
02-22-2012, 10:17 PM | #5 |
It sounds like a ground problem. These tachs need a really good ground to work properly!
