02-22-2012, 11:36 PM | #1 |
engine lacking power
i know this is the wrong yr truck but i thught i might get some help here too,
i have a 1980 gmc, it has a 350 4 barrel it starts and runs fine in park but when you put the truck into gear it loses power and when the trans shifts the truck dies my friend thinks theres something wrong with the trans but iv never heard of an engine doing that over a trans, i was thinking its possibly the carb or a vac line unhooked somewhere when you flip the throttle wide open quick in park it tries to choke out and die |
02-22-2012, 11:48 PM | #2 |
Re: engine lacking power
sounds like a timing issue to me. sounds like your engines timing is wacked out. when your trans goes into gear it brings the rpms down farther, causing it to run really bad. check your timing and make sure its set correctly.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
02-23-2012, 12:16 AM | #3 |
Msgt USAF Ret
Do a compression check first . that will tell you if your mechanical stuff is OK. Look for 120 to 150 PSI on all 8 cylinders. Then check the accelerator pump on the carb. It will give all those symptoms if it isn't working. If you get a good strong spray down the intake then go to the engine forum stickies and look for engine timing . That will give you a step by step guide to timing the engine. It may be listed under engine FAQS. I looked it up for you.....http://67-72chevytrucks.com/vboard/s...d.php?t=290498
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-23-2012, 12:19 AM | #4 |
the engine shuld be fine it only has 35,000 km but it sat for a long time
02-23-2012, 01:45 AM | #5 |
check the cap and roter sounds like a tune up is needed check the vacume hoses as well.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
02-23-2012, 02:16 AM | #6 | |
Msgt USAF Ret
not the problem. I'd guess it's the accelerator pump and maybe the timing. As stated a vacuum leak might cause it too.
02-28-2012, 05:00 PM | #7 |
I'm going to assume that it doesn't have a lock-up converter,but to be certain,raise the hood,and look at the firewall,to the passenger side of the brake booster.Is there a vacuum line running to a small switch,with wires running to the trans,on the driver side,near the shift selector?Also,look at the brake light switch,and see if there are 2 wires(one orange/one white),OR 4 wires(1 orange,1 white,in one connector,and 1lavender/1 brown with white tracer,in the other).The 4 wire switch is for a lock-up torque converter.The converter can sometimes stick if one of the 3 switches sticks:brake sw./vacuum sw./or pressure sw.(inside trans).If it doesn't have the lock-up conv.,it may have a cable to the passenger side of the trans,thats stuck/frayed. If neither is used,chech the carb top for an electrical connector(choke side).That is the idle mixture solenoid.These were known trouble spots.I replaced my carb with an earlier model,because it was dumping so much fuel into the engine,that it took 1/4 tank of fuel to go 2 miles!After changing the carb,replacing the fouled plugs,and changing the oil,it was fine.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
02-28-2012, 05:34 PM | #8 |
78K & 79C Jimmys
if it's got a vac line to the tranny from the carb area
check the vac module @ the tranny seen the rubber/steel line rot and make a vac leak can even knocked that off in the bush
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
