Old 02-23-2012, 03:01 AM   #1
jrobertop88
jrobertop88's Avatar
454ci with 400 or 700r4 tranny
What is better option for the 454, want to haul @$$, and be quick. But save gas too lol, sounds crazy I know, but it can be done right? Lol. The 400 or the 700r4 ? Thanks for the future info fellas.
jrobertop88 is offline   Reply With Quote
Old 02-23-2012, 07:09 AM   #2
brokenspoke
brokenspoke's Avatar
Re: 454ci with 400 or 700r4 tranny
Depends on rear end ratio you have
brokenspoke is offline   Reply With Quote
Old 02-23-2012, 08:23 AM   #3
rbar
rbar's Avatar
If the engine has alot of torque you might consider a 4L80E, but it's going to cost nearly twice as much.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 02-23-2012, 10:10 AM   #4
hd74
i have a 700r4 behind my 454 it has a hwy gear and i avoid drag strip starts. my motor has a high torque . i like it ! when you mean fast that has a lot of meaning
hd74 is offline   Reply With Quote
Old 02-23-2012, 10:34 AM   #5
Batchief909
I have a 454 running with the 400 and 308 rear. I'm happy.
Batchief909 is offline   Reply With Quote
Old 02-23-2012, 10:52 AM   #6
MalibuKasey
Artist
MalibuKasey's Avatar
4L80E is your best bet... atleast... thats what I would do.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 02-23-2012, 11:21 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If your motor is "built" meaning over 450 ft lbs of tourque, the 400/4l80 will be your only options. the 700 just wont handle alot of torque or hard launches with that much or more grunt. no sense in throwing away money IMO. can you get a beefy 700? yes, do you want to spend 3K building one and then nuke it on a burn out? no!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-23-2012, 11:53 AM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I agree with this. If you want a 3 speed go with the 400, 4 speed the 4l80 will be the one.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-23-2012, 11:56 AM   #9
198plus
198plus's Avatar
400
198plus is offline   Reply With Quote
Old 02-23-2012, 08:38 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
The 700R4 is not going to last very long...it's the amount of torque that will eventually be its demise. I would opt for the TH400 or a 4L80.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-24-2012, 01:26 AM   #11
Captainfab
60-66 Nut
I have a TH400 behind the 454 in my Burb and have been totally happy with it except for the highway rpm's. I will be switching to a 4L80E in the near future to lower my highway rpm's and attempt a gain in mpg's. I had thoughts about switching my 3.42 gears for a set of 3.07's, but I like how it launches now. I wouldn't even consider switching to a 700R4 behind a big block.
