Pitman arm/steering box torque specs ?
Greetings,hope to get the correct torque specs on an 81'Chev 1/2 ton 2 wheel drive pu for the following:
-steering box to frame bolts -pitman arm nut at steering box -pitman arm nut at linkage -upper ball joint to spindle nut -lower ball joint to spindle nut -upper ball joint to a arm bolts -lower control arm ubolt nuts -control arm shaft bushing nut upper -control arm shaft bushing nut lower -control arm shaft upper to frame(through shims) -shock to lower control arm nut -shock to fame stud nut -cradle bolts/nuts to lower frame rail Thanks in advance ! ![]() |
Happy to be here
![]() Join Date: Mar 2000
Re: Pitman arm/steering box torque specs ?
Anyone?
I'm not finding anything in my book. Ile look in another in a sec at another book
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Getcha Pull
Just compare the bolt sizes to a chart for standard bolts. That'll do fine. For stuff like the tie rods, tighten them until they feel tight, and move them further until the groove in the crown nut lines up with the hole.
Personally, I'd just do it like I do everything else. "Tight." "Really Tight." "I don't want that falling off!"
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
steering box to frame=65/85lbs. / pitman arm to shaft= 180lbs /pitman arm at linkage= 60lbs / ball-joint @ spindle=50-70lbs.(upper&lower) /upper ball-joint to a-arm=45lbs./lower control-arm u-bolts=85lbs /upper control arm shaft bushing nut =140lbs/ lower control arm shaft nut= 45-50lbs/upper control arm shaft to frame=70lbs /shock to frame stud=90-110lbs /shock to control arm = 65-75 lbs /lower cradle bolts to frame =90-95 lbs. hope this helps. Found it in my Haynes manual( #24064)
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
#6 | |
