02-23-2012, 05:10 PM | #1 |
My 88 SCSB
ok so im doing a complete frame off resto on my 88' its a Basket Case right now. i am gonna put a 96' chrome grille, 96' dash and gauges, gonna run 3/4 or 1 ton running gears(not sure on which) with about 24''s of lift on 52"s!!! im gonna build a 383 to turn the monster of tires.. I havent decided on a color yet but its between Orange and Red. it will have strobe lights in all the lights, its gonna have shaved door handles with vertical doors on remote key. the taillights are gonna be shaved and its gonna have a roll pan replacing the rear bumper with LED strips in the pan for taillights and blinkers. gonna be a fun project!!! will post pics as i go and when i figure out how too!
02-24-2012, 09:24 AM | #2 |
Re: My 88 SCSB
Posted via Mobile Device |
02-24-2012, 11:49 AM | #3 |
Re: My 88 SCSB
this was my starting point.
02-24-2012, 11:53 AM | #4 |
Re: My 88 SCSB
after i found out the frame had been hacked up and was a early model frame. decided on the frame off restoration. im going to get THE right frame tomorrow and we are gonna gusset plate the frame around the steering box so it doesnt crack again
02-24-2012, 12:03 PM | #5 |
Re: My 88 SCSB
so there was only 2 bolts holding the bumper and bull bar on, 1 bolt holding the core support and the radiator was about to fall out! can you say MORONS WITH A WRENCH!!!! but finally got the front clip off and check out there addition to the frame! they attempted to box it in i guess??
02-24-2012, 12:09 PM | #6 |
Re: My 88 SCSB
this is the height and tire size im going after?
02-24-2012, 07:33 PM | #7 |
Chris
Re: My 88 SCSB
wow that's really something.
I never saw an 81-87 frame on a 88-98 truck before. FYI those frames are known for it, but the newer 88-98 isn't from what I've seen, the newer frame is boxed that one isn't. may be why it cracks. How did they make the rest of the truck bolt up to the older frame?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
02-24-2012, 08:20 PM | #8 | |
Re: My 88 SCSB
Greater love hath no man than this, that a man lay down his life for his friends. ~Bible, John 15:13 "All men are created equal, then a few become firemen." !?!?!Go Big Or Go Home!?!?! |
02-24-2012, 09:22 PM | #9 |
Chris
Re: My 88 SCSB
no doubt man. I saw the bumper and thought hmm they made bracket for a squarebody/81-87 bumper on the newer truck, then I saw you had hacked frame and looked at pics lol.
02-24-2012, 10:35 PM | #10 | |
Re: My 88 SCSB
02-27-2012, 09:33 AM | #11 |
Re: My 88 SCSB
well i didnt gt the cab and the bed off bc the beds welded to the frame!! so now i gotta find away to break the welds or cut them? but here's a few pictures from over the weekend!
heres the new frame i had to work my a$$ off for!
02-27-2012, 09:37 AM | #12 |
Re: My 88 SCSB
and you cant work on a project with out having a lil more fun so we added some bud light platinum and a nice warm fire!
Cowboy drinkin a nice cold one!
02-27-2012, 09:48 AM | #13 |
Re: My 88 SCSB
it looks nice and sits nice but man someone really made that a hack job. at least your trying to fix it the right way. thats a clean looking frame cant wait to see it done
IM ONLY 18 AND LOVIN IT IF MUD AINT FLYIN YOU AINT TRYIN! 1badgmc- Just think. Someone worked hard to make it look that bad. 1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945 1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873 1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build 1998 GMC K-1500 ECSB 305 auto partd truck 1999 GMC K2500 suburban 350 4x4 Dads project 1981 Corvette 350 auto Also Dads project 1989 Corvette 350 auto ^^ 1998 GMC K1500 ecsb 305 auto Brothers project |
02-27-2012, 10:12 AM | #14 |
Re: My 88 SCSB
man its horrible! and yea im gonna do it all right i dont take short cuts.. but im ready to see the finished product to but no hurry here lol
02-27-2012, 10:19 AM | #15 |
Re: My 88 SCSB
sounds good its gonna look great
02-28-2012, 03:22 PM | #16 |
Re: My 88 SCSB
well i gotta cut the welds to get the bed off the frame bc its welded!!! and how would i go about changing my dash out?? what do i have to change??
02-29-2012, 06:26 PM | #17 |
Chris
Re: My 88 SCSB
you know that's a 2wd frame right? The new one you got.
02-29-2012, 08:06 PM | #18 |
Re: My 88 SCSB
Yea it shouldn't matter since I'm doing a SAS should it?
02-29-2012, 09:28 PM | #19 |
Chris
Re: My 88 SCSB
it does when you get the SAS kit, most are made for 4x4 frames but they do have 2wd specific ones, not sure if there's any difference or not.
you doing a SAS, let me ask some questions, what gauges does it have for speedo and does or did it work? I ask because the 88 uses a vss or electric speedo, and the older t-cases use cable or what not. The newer cases with vss also have DS drop axles, not ps like the older gm's. If you want the speedo to work it costs money for adapters or you can use a mech gauge or what not. The 88-91 burb and blazers have a PS drop np241 that has the vss and would work perfectly, or you can use what you got, but using a PS drop t-case requires trans crossmember custom built or fab work to an old one and alot of it.
02-29-2012, 09:46 PM | #20 | |
Re: My 88 SCSB
03-15-2012, 12:24 PM | #21 |
Re: My 88 SCSB
Well a lil change of plans my build is gonna be a slammer! Finally got the bed and the can off and changed my mind so now it's gonna be a 2wd with a 4/6 drop. I bought another 4wd that's pretty cleans. I have the bed on now and it's how the ride height is gonna be
