Old 02-23-2012, 08:32 PM   #1
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
Help with the cowl hood please????????????
I have a problem. I have a 1970 Blazer that I put a 1968 front clip. I had the clip but no hood. But that wasn't a problem because I wanted a cowl hood anyways. The goodmark cowl hood had a bracket on the hood but no bolt that holds it down. I took one over but it want into the hole without threading it, too small. My question is "Do the cowl hoods came wth brackets or did he possibly put on the wrong bracket on it" Any help would be helpful, thanks.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 02-23-2012, 10:02 PM   #2
Dynomutt
Dynomutt's Avatar
Re: Help with the cowl hood please????????????
I'm REAL confused by your post. Not sure if I can help because I'm not sure what you're asking. Maybe someone else can help or maybe you can be more specific about what you're trying to d. What bracket are you working on? My hood came with NO brackets or hardware. It was the sheetmetal only and I had to use all of the hardware from my old hood.
Wish I could be more help for ya.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 02-23-2012, 10:32 PM   #3
71HUGGER396
I'm talking about the bracket that is on the front of the hood. It holds the bolt that has a cone shaped end that goes into the latch assembly. The bolt I used was from a 1972 GMC. Are all the years the same on that piece?
Old 02-23-2012, 10:54 PM   #4
crewcab67
Yes they are all the same i have put a lot of the cowl hoods on i used the original bracket just pull the 4 bolts out and put it on the new hood. hope this helps
crewcab67 is offline   Reply With Quote
Old 02-24-2012, 06:51 AM   #5
71HUGGER396
Yes, thank you.
