I've got her to run, but need her to stop.
Hi all,
Been awhile since I last posted, anyway here's my problem. As I posted a while ago I was in the process of changing over to front disc on my '69. It took me a bit but I finally got it finished (somewhat). Here's what I've done so far: 1: swapped out the front end (that's a given), replaced the discs, pads, hoses, calipers and bearings. 2: bought new drums for the rear. 3. made new hoses (lines) to match the new setup. 4. Bled the **** out of the system, I now have clear fluid running to all the wheels. What I didn't change was the booster or master cylinder. My problem now is that when I got to stop I don't have any brakes on the first attempt. But, if I lightly pump the pedal the vehicle will damn near lock up. I hope that someone out there can give me some advice on this matter. I would sure hate to have to take it into the shop and pay someone else for something I should fix. Thanks.
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock. The front end disc swap is finally complete ![]() 2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out. |
![]() ![]() Join Date: Jul 2002
Sounds like master cylinder is going bad....plus since you now have discs..you should change to a disc brake master cylinder and proportioning valve...otherwise your brakes are going to be super erratic and may cr@p out alltogether at the most inconvient time.
I agree with Palf70step, cylinder and valve may need replacing.
huh?
![]() Join Date: May 2000
Nice Avatar
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
If you did all that work on the brake system, you should always change the master cylinder!! (cheap investment)
When I changed over to the new system, I used the master cylinder and proportioning valve from the donor vehicle. You may be right and I'll have to try swapping in a new one.
One other thing.....the MC that I have now has two bleeder screws at the base (one for front and one for rear). When I went to the store to get a new one it didn't have the screws. Should this be a concern or not? If all that has been said is true, then I still don't understand why the brakes would be so touchy. Is it because I have gotten used to the plush style of the new vehicles and lost my touch with the old school? Since I didn't replace the valve with a new one could that be the cause?? If not what other routes could I pursue??? Thanks again.....
