Old 02-23-2012, 10:26 PM   #1
TRC911
Axle/wheel question???
Hey guys. I got a set of 15x10 wheels for free and have some 32x11.5s sitting around
I was told by a friend that the wider the wheel, the easier it is when off roading to bend the axle???
I thought having wider wheels would help even out the wear on tires. any info is needed as I was looking forward to getting them mounted up and rolling in style
I don't want to swap if this may hurt the axles
TRC911 is offline   Reply With Quote
Old 02-23-2012, 11:41 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Axle/wheel question???
Both are somewhat true. Skinny tires don't wear evenly, but its really up to the tire. As for running wider tires you add more leverage to each end of the axle housing. Now bending your axles? You'd have to be really hard on your truck and would be more likely in a rock crawling event or jumping your truck. If you run wider wheel and tires and are a mild to med off-roader you will be fine. Hope this helps.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
