Fixing to put guts in freshly painted doors and i am dreading it
I have read up on the "how to's" but i still am afraid i will scratch new glass or black paint.Do i put window felts and glass runners in before i put glass in door.My plan is to install mirrors,door handles and locks,regulator,door glass,vent windows in this order.When do i put felts,glass runners in?
![]() Join Date: Nov 2004
Re: Fixing to put guts in freshly painted doors and i am dreading it
Felt goes last. Use lots of painters tape to keep scratches off, line the whole top of the door, inside and out.
You're order seems fine. It's been a long time since I did mine, but I think I had the stuff in the door, with the vent window loosely screwed in. I then lined up the glass/regulator with their slots in the door and glass, then moved the regulator into position and loosely screwed it together, then the angled runner was last. The channel felt will slide down into the door just fine. Get your vent window tight and everything else tight, roll down the window, and start the channel felt tight to the vent window, do the top of the door, then slide it down into the channel, you should be able to slide it a bit for a good fit. Inner felt and outer rubber strip go on last. I haven't done mine since 2006, but I think that's how I did it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Its a Truck Thing......
Like stated above.....Tape is your friend and take your time.....Been there done that....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Tape Tape and more tape. Install the regulator first- be sure you have it with the correct door. Install the inner roller in the door track and bolt the reg. in loosely. Roll the reg to the top of the door and install glass into reg. Roll window down and slightly push glass toward the front of the door (but not out of track). Install the rear support into the door but do not bolt down I just let it lay against back of door. Slide glass to rear of door and Install vent window. You will have to turn 180 * to get to install and gently put it into place at the corner. Be sure the rubber is inside the door frame for vent windows and screw down using the three screws at the door frame. Slide the window forward and install the window frame rubber. Once the rubber goes down into the door you will have to work the felt into place at the rear frame corner and the lower support track. Loosely install the upper screw/bolt 1/2" then install the lower two phillips screws. Install the phillps screws fro the vent windows and roll up the glass to help finally seat the felt into the lower track and rest of frame. finally install the inner and outer wipes with the windows rolled down. You will have to look at the position of the clips and this wwill be the place you will most likely run the risk of scratching the paint if you are not extremely careful! Trim the wipes as ness. to insure the best fit and move to the other side and the clips are snapped into place. This is easy if you take your time but dont be timid, If it were rocket science we would all be flying to the moon.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Just like to part out trucks!!
WOW great info guys!!!! Thanks
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Great info but I too am dreading this.
Posted via Mobile Device |
If you wasn't on the other end of the state I'd come by and help you with it, I've rebuilt a few doors, these fella's have already told ya what you need to do just take you're time if you get agrivated walk away come back later don't force anything.Check these links out.
http://67-72chevytrucks.com/vboard/s...d.php?t=460960 http://67-72chevytrucks.com/vboard/s...d.php?t=157539 |
Thanks for the great info.When i read the 2nd. link R.L. posted i have to scroll over left and right.When i print it i can't read all of it it cuts out some of the right side words.I have run into this before when trying to print something.How can i correct this so i can see the whole page when printed?
