02-24-2012, 11:34 AM | #1 |
Rear End Posi
Just wondering what are my rear end options for and 87 2wd model. I would like to go with a something other than the stock 3.08 in it now but also incorporate either a posi or LSD...Thanks
02-24-2012, 12:37 PM | #2 |
Moderator
Re: Rear End Posi
Which axle?
02-24-2012, 05:32 PM | #3 |
Parts and more parts
Re: Rear End Posi
I and my son are running 12 bolt axles with 3.73 gears under our 84 and 86 SWB trucks.
Frank |
02-24-2012, 05:44 PM | #4 |
Re: Rear End Posi
I am running a 10 bolt rear...drivetrain is an LSX 5.3, carbed with mildly built th400. Just looking for a better gearing for that racing feel...will 4.10 be too low of a gear for driveability. And will i need posi rear for better performance. Thanks
02-24-2012, 06:15 PM | #5 |
Re: Rear End Posi
Go to 355 or 373's depending on how much "racing feel you want"
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-24-2012, 08:21 PM | #6 |
Re: Rear End Posi
How tall of tires are you going to run? A 400 with 4.10s is a stump puller, but gas mileage is not in your fuiture.
Frank |
02-25-2012, 01:59 PM | #7 |
Re: Rear End Posi
I've got 3.73's with a Detroit Tru Trac setup in my 10 bolt. Ive also got a 700r4 trans though. Tires are about 27" tall overall. Honestly in over drive on the freeway it's tacking about 2400 at 65-70 mph. With a turbo 400 it would be screaming. My mileage dropped a little when I got rid of the 3.08's. But it was a night and day difference power wise. Truck is a lot quicker and more responsive.
Posted via Mobile Device |
02-25-2012, 05:50 PM | #8 |
Re: Rear End Posi
Thanks folks. That is just what i needed. I think I will go with just a 3.73 gear. Im committed to the th400 since I have 3 of them and they are a cinch to rebuild although the 700 would be nice.
02-25-2012, 06:34 PM | #9 |
Re: Rear End Posi
I yanked the 3:08's out of mine and put in 3:73's Richmond's with a Auburn Cone Clutch carrier. Very happy with it. I had a THM400 in it for awhile but decided to go back to a 700R4 after swapping the gears. Tires are 31's and at 70 mph I'm getting about 2000 rpm where I was getting about 3000 with the THM400. 700's are easy to build too, just make sure you use a 85 or later model at the bare minimum but a 87 or newer model is better yet.
02-25-2012, 10:26 PM | #10 |
Re: Rear End Posi
It's been suggested to me that unless you have overdrive 3.08 is the lowest you'll want for the street. The 700R4-equipped trucks employed 3.73 off the assembly line because of the overdrive. You'll run out of room on the highway with a low gear and only three speeds pushing it. Fuel economy? What's that?
Not sure if the 10-bolts have 30 spline axles, if so you can get an Eaton posi or LSD carrier and use the same gear and pinion. Call a friend to help you with this upgrade or find a local shop who can do it for you. A shop in Houston quoted me $850 for a posi conversion a number of years ago for a Dodge project I was working on, but lucked out and found an entire 3.36 assembly for $150 instead. This is really beyond my depth so I stand to be corrected if I'm wrong. Unless you want to burn tires, gas and a bigger hole in your pocket go for it, or keep your 3.08 peg leg and change the oil when it needs it. |
02-26-2012, 10:46 PM | #11 |
Re: Rear End Posi
Believe it or not alot of the factory 700'd trucks came with 3:08's as well, mine being one of 'em. Thing would almost idle down the freeway! 3:08's were good when I wasted the 700 and put the 400 in but once I wasted the one legger rear I opted for the 3:73's. Built a 700 for it not long after doing the rear since now she was screamin' down the highway....
02-26-2012, 11:47 PM | #12 |
Re: Rear End Posi
I guess I will just pony up the dough for an LSD.3.42 may be a better comprise. I running 20 inch 245/50 tires. There is a guy on this forum with an awesome flat black square pro street with like 15 inch rears. He has definitely got me thinking.
02-27-2012, 01:03 AM | #13 |
Re: Rear End Posi
I am running the 3:08 700 combo and I hate it! It's getting 3:73 posi as soon as I can.not sure if the 700 will hold up to the 406 I built.plus I got a nasty converter already for a th350 so I'll probably go with a th350 .I ran as much as 4:56 on the street,high way was out of the question but damn thing would pull so hard it would flatten your eyeballs !!
02-27-2012, 01:20 AM | #14 |
Re: Rear End Posi
I hear ya there! Hated the 700/3:08 combo too. Very happy with the 3:73/700 setup. Great around town and on the freeway. Just a good all around set up in my opinion.
02-27-2012, 12:10 PM | #15 |
Re: Rear End Posi
