Old 02-24-2012, 05:28 PM   #1
sox8145
drop kit
whats up guys i just orederd a belltech drop kit 4/6 with spindles flip kit and c notch. I just had a few questions about what i would have to change. im running 8'' rallys in the front with 275/60/r-15 tires would i have to change them to a smaller width so they woint rub? Also i have long tube headers should i go short or will i have no problem with them not rubing
sox8145 is offline   Reply With Quote
Old 02-24-2012, 05:47 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: drop kit
A 5-6 drop is what my friend has on his rig. He has some header issues with some speadbps and sorts but not to awfully bad
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-24-2012, 07:01 PM   #3
bbbc10
Diggin The SquareLife
Re: drop kit
i have 5/6 an i had to change headers....u should be ok on tire size though
bbbc10 is offline   Reply With Quote
Old 02-24-2012, 07:26 PM   #4
rwhit57
rwhit57's Avatar
Re: drop kit
I have basically that setup. The headers probably will be ok, I have long tube headers and I've never hit them. Running the rallyes you will probably have to grind on the lower a-arms for clearance, and maybe the spindle and caliper a little, none of that is unusual.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-24-2012, 07:31 PM   #5
sox8145
Re: drop kit
Ok cool I'm not gonna install it I'm gonna have a local shop do it I'll be sure to let them no
Old 02-24-2012, 07:44 PM   #6
rwhit57
rwhit57's Avatar
Re: drop kit
Unless they are familiar with lowering these trucks they may not grind the lower a-arms for you, citing safety reasons. I would talk to them about it first. The spindle and caliper are no big deal there is plenty of material there, but I could see a front end shop not wanting to grind what it takes to make a 15" wheel fit. Just thinkin.
Old 02-24-2012, 07:52 PM   #7
rwhit57
rwhit57's Avatar
Re: drop kit
This is not a great pic, but might give you an idea. This is what I had to do mine to get rallyes and my aluminum 15" wheels to fit. As long as you don't get into the rolled area the strength is still there, but it looks scary.
Old 02-24-2012, 08:32 PM   #8
sox8145
Re: drop kit
Dang that does look scary do u have any problems with it while ur driving
Old 02-24-2012, 08:53 PM   #9
rwhit57
rwhit57's Avatar
Re: drop kit
Zero. Drives fine about 20k on it since spindles.
Old 02-24-2012, 11:18 PM   #10
sox8145
Re: drop kit
do you thinkit would be better to go control arms and springs?
Old 02-24-2012, 11:35 PM   #11
rwhit57
rwhit57's Avatar
Re: drop kit
No, spindles and coils is the way to go as far as I'm concerned.
Old 02-24-2012, 11:49 PM   #12
INSIDIOUS '86
Re: drop kit
Drop arms WILL bottom out when used with drop springs
Old 02-24-2012, 11:53 PM   #13
sox8145
Re: drop kit
So i guess the only thing is to grind it. How much did you gring on yours?
Old 02-25-2012, 12:20 AM   #14
rwhit57
rwhit57's Avatar
Re: drop kit
Until it just cleared lock to lock without touching.
