Active Member
![]() Join Date: Mar 2005
temp sending unit question
First ,Do temp sending units fail and cause hi temp reading?
my truck has 67? - 72? stock gauges but not original to my 67. It has a GM crate 350 that was resently installed. Just when it gets warmed up it peggs the temp gauge. I didnt believe it was correct but I bought and installed new thermostat same thing, new water pump same thing. And then a cheap tremp gauge at Kragens and its running just under 190 steady. So I am guessing the sending unit that came with the GM Crate 350 has failed or is incorrect for the old gauges Any Ideas would be helpful. I would like to use the stock gauges.
67 short step ![]() 71 Custom ![]() |
#2 | |
Re: temp sending unit question
Eat, Sleep, Drive a Chevy
Sending units are diffrent for use with gauges or use with idiot lights.
The one in the engine could be for a light good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
mine reads hot but aftermarket guage shows good, no change after a new sending unit. drove me nuts
