02-24-2012, 09:16 PM | #1 |
Crank pulley for an 88-up 454
Looking for one for my car build, has to be off 88-up with single groove serpentine setup. Lemme know what you got....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
02-25-2012, 02:01 AM | #2 |
Re: Crank pulley for an 88-up 454
You're looking for the serp style alt/water pump/crank set-up w/the remaining accessories v-belt?
02-25-2012, 09:13 AM | #3 |
No just the crank pulley. I'm gonna be using SBC serpentine setup, everything off the donor engine can be used, but need said big block pulley. There is a kit on evilbay that bolts to the block, then the brackets bolt to them. They give a part number for the pulley, the one that I have doesn't match this number. Dunno what is different, but it's off a 91 or 92 3500HD truck. I don't have the any of the parts yet to test fit to see if it would work or not. If I can find the right one, be no questions. Part number I need is 10085753.
02-25-2012, 12:46 PM | #4 | |
I opted for the easy way out & got the billet adapter to use w/the 'dime-a-dozen' sbc stuff....
02-25-2012, 01:47 PM | #5 |
Hmm, know where to get this adapter??
02-25-2012, 05:03 PM | #6 |
02-25-2012, 08:31 PM | #7 |
That is sweet. I did some checking on the one that I have, think it's the same thing, just different part number.
02-25-2012, 10:20 PM | #8 | |
I'm using a higher end WP (Stewart Components) but BBC CCW rotation WP's should all be the same size. My WP/fan pulley is easily .250" off vs. the rest. I hit several parts stores today looking for spacers w/no luck. I'll have to wait until next week & hit my local Smiley's perf shop for some.
02-25-2012, 11:00 PM | #9 |
Using that spacer is an option if my pulley won't work. But eventually I will have more accessories to line up, which could be interesting...
