Old 05-01-2003, 08:05 PM   #1
miket
miket's Avatar
Tranny Cooler lines???
Need to replace them..would you go:
OEM steel
Stainless Steel
Or custom build 'em with aeroquip fittings and high temp/pressure hose?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 05-01-2003, 09:56 PM   #2
BobM
Check out http://www.inlinetube.com for new lines.
BobM is offline   Reply With Quote
Old 05-01-2003, 09:58 PM   #3
Low69CST
I'm building mine with russell & earl's an fittins. I've got the flare & pipe adapters, but still tryin to save up enough money for the (4) 90 degree hose ends I need: $15 bucks each! plus 20 ft. of hose which is 90 bucks!
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-02-2003, 12:16 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm bending my own. Real cheap that way...and they'll last 20 years or so.
Old 05-02-2003, 02:25 AM   #5
BUXMAN66
go bucks!
i'll tell ya,it's a real bit%h to get the lines in w/motor ,core support, body,....etc in the way.got some s/s lines for my th350,could'nt get the lines to go between the frt. crossmember and the inner frame rail w/o bendin' the hell outta 'em.i came to the conclusion that the only way to put 'em in is to be doing a complete body off resto.what good is nice shiny s/s lines if you have to bend the crap outta them.i personally like the nice straight 90 deg. angle as they enter/exit the radiator bungs,instead of twisted and "re-aligned" to make fit. my remedy: bought a tranny cooler at summit, either 7/16" or 1/2" dia. tubes w/ barb fittings already provided.fits perfect in the inner frame-rail on drivers side. just my .50 cents worth.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
