Old 02-25-2012, 01:09 AM   #1
BCOWANWHEELS
looking for DANA 70 POWER LOCK
GUYS I,am looking for a power lock for a early model dana 70 axle, for 4.56 and up gears and preferably 23 spline axle gears. these are whats called a 1/2" or .500 offset carrier. there made from late 1950's to aprox 1973. the newer dana 70's are whats called the .625 or 5/8" offset carrier and this wont work in my old housing. anybody got one ? I dont mind rebuilding it or changing the axle gears. if you think you have 1 send me a price delivered to 37664 and the I.D. NUMBERS OFF the case so I can make sure its what i need. these was in 1 tons trucks like special order chevys, ford, dodge, I.H. ETC.
bob in tn.
1-423-384-8938
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-25-2012, 01:13 AM   #2
dbash
Re: looking for DANA 70 POWER LOCK
Originally Posted by BCOWANWHEELS View Post
GUYS I,am looking for a power lock for a early model dana 70 axle, for 4.56 and up gears and preferably 23 spline axle gears. these are whats called a 1/2" or .500 offset carrier. there made from late 1950's to aprox 1973. the newer dana 70's are whats called the .625 or 5/8" offset carrier and this wont work in my old housing. anybody got one ? I dont mind rebuilding it or changing the axle gears. if you think you have 1 send me a price delivered to 37664 and the I.D. NUMBERS OFF the case so I can make sure its what i need. these was in 1 tons trucks like chevy, ford, dodge, I.H. ETC.
bob in tn.
1-423-384-8938
http://i.imgur.com/4Kkfn.jpg
http://i.imgur.com/2mCAG.jpg
forgive me if this is not what your looking for, I am still trying to figure it out exactly. Truck is a 1 Ton 1971 Chevy Cab and Chassis built in fremont, CA.
dbash is offline   Reply With Quote
Old 02-25-2012, 01:15 AM   #3
BCOWANWHEELS
dbash, that is a early 14 bolt chevy corp. rear axle. but thanks for the pic,s.
Old 02-25-2012, 01:19 AM   #4
dbash
thanks, good luck with your dana 70.
Old 02-25-2012, 01:21 AM   #5
BCOWANWHEELS
you might want to see if your 14 bolt has a detroit locker in it and what gear ratio it has as these bring big bucks now days.
regards
bob
Old 02-25-2012, 01:24 AM   #6
dbash
I will pull the rear cover tomorrow..... may I send you a pic afterwards? Not to kidnap your thread....
Old 02-25-2012, 01:26 AM   #7
BCOWANWHEELS
no problem. you count the number of teeth on the ring and pinion gear to get ratio and as far as a locker its inside the carrier and you cant see it without pulling & dissasembling it unles you can drive the truck , then just do a little burnout and see if just 1 tire pulls or 2.
Old 02-25-2012, 01:30 AM   #8
dbash
I wish I could drive it, truck is stripped down to a rolling chassis. I can pull the covers off of both the front and rear though....
Old 02-25-2012, 01:32 AM   #9
BCOWANWHEELS
There isnt a cover on the front ! Just the back. Theres also probably a tag on the back cover bolt that will tell you spec's also on glove box dorr inside.
Old 02-25-2012, 01:35 AM   #10
dbash
sure looks to me like there is a cover bolted on the rear and the front that could be taken off after the drive line is removed.... maybe I am wrong.
No reference to the rear axle on the glove box I checked.
Old 02-25-2012, 01:35 AM   #11
BCOWANWHEELS
Cover on back chunk in front
Old 03-05-2012, 08:00 PM   #12
BCOWANWHEELS
Ttt
Old 03-05-2012, 09:53 PM   #13
Dana 70s were 73-up Big Dooley rears. You'd do better looking in the right parts board. No '72 or earlier GM trucks used the Dana 70.
Old 03-06-2012, 03:37 PM   #14
BCOWANWHEELS
Wrong ! D70's was late 1950's and up and most was srw in 1 tons. The p/l i need is late 50's to 1973 "only" but thanks for your comments. I,ve dealt with 60's & 70's for almost 40 yrs.
Old 03-07-2012, 08:50 AM   #15
Sorry,I didn't mean to hurt you feelings. I was trying to help. It sounds like we have dealt with these trucks for the same amount of time. I know the Dana 70 existed in other makes,but GM had their own rear and only began using Dana 60s in some 3/4t trucks 65-72. Then,beginning in '73 they started using the Dana 70 in dual rear pickups. In the 46-72 GM parts catalog there are no listings for any parts for Dana rears until '65 and only on C20,which would not be a Dana 70. They show no parts listings for any 30 series truck w/Dana. That,and in 40 years or more I have never seen a Dana 70 in any GM truck prior to '73. I know the one you're looking for,the early Dana 70 (no suffix) that was used late-50s into '71 when the Dana 70B replaced it. Good luck on your search.
Old 03-07-2012, 05:09 PM   #16
BCOWANWHEELS
Alot of rears got transpalnted especially when the early 14 bolt got hard to get parts for. I know what came in 67-72 trucks. Thats irrelivent. But unless you have or know who has what i,am looking for you shouldnt have posted. And you didnt hurt my feelins.
Old 03-08-2012, 10:53 AM   #17
That's just it,I thought I knew someone who would have what you need. That's what drew me to your thread. It's important to know what the rear came out of,though. This is a 67-72 GM Truck parts message board and I never knew this rear to come in one and I said what I said because I know a lot but never figure I know it all. I did some checking and now know it did in fact not come in these trucks and there was only one no suffix Dana 70 w/.50 offset,which my friend does have parts for. I made a suggestion that there may be a better area to post your WTB since no truck within this range ever used that rear. I now know this rear was never used in any 73-up GM Dooleys,either. Many people offer unsolicited advise on this site,as that's what this site is about...knowledge as much as or more than just a marketplace. I don't need to be told where to post and when. And,I won't tell you either. It's not my place to tell you there is a WTB and misc. sale area here that would be the appropriate area to post your needs,which is why I didn't. I'll leave you to your search and,again,good luck.
