05-01-2003, 10:22 PM | #1 |
Parts Washer
What does every body use in there parts washers for cleaning?
I went to advance auto and they want almost $35/ 5 gallon pail.It's used full strength.Thats $140 for a 20 gallon washer. I thought that was kinda high.Any suggestions.What works good and don't leave any residue?Thanks for anything,Mike
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
05-01-2003, 11:31 PM | #2 |
Cantankerous Geezer
I go to the local Co-op and buy safety solvent in bulk (take your own cans). Last time I bought some it was around $3.25 a gallon. Your 20 gallon washer takes 12 gallons to fill it.
Fred There is no such thing as too much cam...just not enough engine. |
05-01-2003, 11:56 PM | #3 |
its all about the +6 inches
Depending on how much you'll be using it...and what you'll be cleaning...a dish washer is pretty dang awsome.
You can get leakey ones for free all day long and install in the garage. Some one posted a pic about 6 months ago of his clean parts coming out. |
05-02-2003, 12:46 AM | #4 |
I go to a fuel supplier and buy parts degreaser for $2.35 a gallon . You can also get a detergent concentrate from harbor freight for some thing like 6 or 7 bucks a gallon , that you can mix with with water and it is enough to fill your parts washer but it works slower then degreaser .
05-02-2003, 08:30 AM | #5 |
Hey or you can do it the old school way.a little oil drain oan,a brush and gasoline!!!! Ive dont it like that in the past!!!!skin didnt care for it!its a cheap alternative
05-02-2003, 09:50 AM | #6 |
we got ours free from my dad's shop. they were going to throw it away, but it came with 2 5 gallon buckets of varsall (sp?). excellent stuff.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
05-02-2003, 09:55 AM | #7 |
NEVER, ever use gasoline to wash parts, the flash point is way too low. Try Desert Rats suggestion using diesel fuel. This way you are not circulating dirt fluid continuously. When the diesel gets dirty pour it out and put in some fresh fluid.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
05-02-2003, 02:36 PM | #8 |
Remember, it lasts pretty good too. The dirt settles to the bottom and you can get years of use out of the same fluid if you aren't using it like a commercial shop. I try to scrape off the worst crud before I use the washer and my fluid has stayed fairly reasonable and it has been in there at least 2 or 3 years.
1968 Chevy - 292 with a powerglide |
05-02-2003, 02:48 PM | #9 |
I used in my small parts washer..... simple green 30%, Castrol Super degreaser 50% and water the rest (approx values)
Seemed to work great |
