Old 02-26-2012, 08:31 AM   #1
Rogier
Modern AC upgrade
I've been searching, but haven't found the answer. The 1980 (model 1981) squarebody crewcab project I'm working on has all the original heating/AC stuff in it. Now I've bought an upgraded 1996 vortec engine and this has an AC compressor on it from a 1996 C1500.
Can I just connect the old hoses to the new compressor?
Anyone have the wiring schema?
Do I need a new 'heaterbox' from a C1500 on the engine side of my firewall?
All tips and tricks are appreciated, lessons learned and pics are even better!
Rogier is offline   Reply With Quote
Old 02-26-2012, 08:48 AM   #2
andrewmp6
Re: Modern AC upgrade
I believe you just have to have new lines made for the compressor and wire up the compressors clutch.
andrewmp6 is offline   Reply With Quote
Old 02-26-2012, 08:52 AM   #3
Rogier
Hi Andrew, thanks for the reply, so you're saying: Reconnect the plumbing, fill it and fire it up?
Old 02-27-2012, 04:12 AM   #4
andrewmp6
I believe it should work but not 100% on that i haven't done that before,But i know you can take a older car or truck and upgrade the compressor to a modern sanderson.Only thing i can think of being the truck was a 96 its probably 134a so you might wanna get a convert kit for 1980 ac stuff.
Old 02-27-2012, 09:04 AM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Have the hoses made, fill it and fire it. It will work fine. I would replace the reciever dryer while I was there.
--Josh
Old 03-02-2012, 11:16 AM   #6
Sully Erna
Sully Erna's Avatar
When i did the serpentine conversion i used a '97 blazer v6 serpentine with the blazer style compressor. I tried to crimp my ends on to my '85 hose but they leaked so I went to old air in ft. worth and they charged 75 a piece for a new hose with '85 condenser and dryer ends and the compressor end is a #8 and a #10 screwed onto an adapter that would fit the blazer compressor, that was about 20 from old air. I was already on 134a.
If you need more details or part numbers just post here and i will get it on this thread.
Sully Erna is offline   Reply With Quote
