1 ton k3500 rolling sideways...
the other day , my friend was following me and he told me that my truck is kinda rolling sideways. also gotta correct the steering to go straigh. frame is straight . but is it possible some broken center bolt on one of the diff.? is it a popular problem?
Re: 1 ton k3500 rolling sideways...
Have you checked your leaf springs and shocks. i've hear of this happening when they get knocked loose
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
ive visualy checked but will need to take the wheels off i guess...
4wds can appear to be crabbing because the front track width is wider than the rear. Did your friend look at both sides? It's kinda hard to check the right because the following vehicle has to be way right for the driver to see.
TIP: Drive it slowly through a wet area,to a dry area,for 20-30 ft.Any "dog-tracking" will show up as uneven tracks.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
well i could use my drive way its long enough and its full of snow .. but dog tracking..? what does that mean?
If you've ever watched a dog track a scent,you might notice that the dog's rear legs are to one side.It helps fool anything following them. So,"dog-tracking"on a vehicle,is caused when the axle doesn't follow the front wheel tracks.It's usually caused by a broken spring,hanger,u-bolt,or the bolt that centers the axle housing on the spring. Another way to verify it, is to measure the distance from the front of the tire,to the wheel opening,on both sides.If they're different,it means it will "dog-track",which causes steering problems,using more fuel,and tire wear.It may cause a lean in the body,also. If your truck has a straight front axle,measure front and rear.
#8 | |
C35 Crew Dually
it "Tracks" to one side or the other.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
ill have to measure front axle to rear no more rear fenders lol by the way those plate on the frame were used to hold commercial fifth wheel setup
Measure from the cab to the center tread of the outside tires,then.From the picture,I'm betting the right side is farther back,indicating a problem.
i also suspeted the rear springs the right ones are missing the bolt in the u bracket that holds them together its must have hit a big hole. they might be cracked and they are rusted. i plan on installing comercial ones like on the wrecker and get rid of thoses air bags.
Well,that would do it!It's probably sliding around,as you drive,so it would really be a challenge to keep it straight. Good luck with it,my friend.
