Old 02-26-2012, 11:48 AM   #1
Tal7123
1969 Chevy C-10 Cowl Replacement
Hi Chevy Fans
I am pretty new to the cite, I just bought a 1969 Chevy C-10 pickup it was the old orange shop truck off ebay. It was surpose to be super solid, but after inspecting it closer the cowl will need to be replaced. Yeap, I know I paid too much!
I wanted to know if any of you has done this procedure. If so can you direct me to a thread with plenty of pictures. I will be doing the work myself. I can weld and have taken a few body classes, but I always have been afraid to rush into the big projects. Therefore, I normally just pay someone else to do it. I really want to do this one my self and I have set a budget on this truck. It is an old shop truck, it will be used to tow my classic car to the car shows. With the exception of the cowl being totally ate out on the corners, a patch panel or two on the firewall, toe panels (the vent hole are ate out) , and patching the corners of floor panel, it is really in good shape.
Additionally, I thought about blocking off the cowl and just making or installing some other type of fresh air system. Any ideas or suggestions.
Tal7123 is offline   Reply With Quote
Old 02-26-2012, 01:47 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 1969 Chevy C-10 Cowl Replacement
Got any pictures of the truck or the rusted areas it would give a better anwser to give you.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-26-2012, 01:58 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: 1969 Chevy C-10 Cowl Replacement
Welcome,
Yeppers pictures and make sure we get to see the classic car also!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
