Old 02-26-2012, 12:04 PM   #1
boatpuller
boatpuller's Avatar
rear disc conversion
i read some search results.but,wasn't feeling informed.anybody done it lately with pics?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 02-26-2012, 02:07 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: rear disc conversion
I have, I'm using captain fab brackets, astro van AWD front rotors, wilwood d-52 calipers, disc disc prop valve, I'm also using front d-52s, stainless braided brake hose all the way around, and wilwood master cylinder
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-26-2012, 02:09 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Is that setup a lot stronger than the stocks set up. do you stop faster with less brake fade and better proportioning?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-26-2012, 07:34 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Yeah good luck with you wilwood brakes. They don't back up their warranty on anything. Once they've got your money they're done with you.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-26-2012, 09:34 PM   #5
boatpuller
boatpuller's Avatar
[QUOTE=flamingbig10;5213786]I have, I'm using captain fab brackets, astro van AWD front rotors, wilwood d-52 calipers, disc disc prop valve, I'm also using front d-52s, stainless braided brake hose all the way around, and wilwood master cylinder.
thanks aaron...do you think you saved a few bucks going that route as opposed to buying a full kit?
Old 02-26-2012, 09:36 PM   #6
boatpuller
boatpuller's Avatar
sorry for the double.hopefully someone will delete the first for me.
Old 02-26-2012, 09:38 PM   #7
J Knight
J Knight's Avatar
Is there a provision for an emergency/parking brake on any of these rear disc brake set ups?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-27-2012, 12:04 AM   #8
BLE 'BURBAN
http://www.blackbirdscustomtrucks.com/index26.html
'nuff said.
EXCELSIOR!!!!
Old 07-25-2012, 01:22 PM   #9
bark
that looks like a clean setup, what prop valve did you run? a wilwood, I see they have an sdjustable disc/disc. or did you just run a pre set?
thanks...
bark is offline   Reply With Quote
Old 07-25-2012, 01:37 PM   #10
wyattglock
wyattglock's Avatar
I used the Right Stuff PV72 prop valve, DIY4x brackets, front calipers from an 85 C-10, rubber lines for an 85 C-10 for now, and the stock hydroboost master cylinder on my dually. All total I had around $350 in parts. I have pics on my 89 crew cab resurrection thread on this site.
wyattglock is offline   Reply With Quote
