Old 02-26-2012, 12:32 PM   #1
rkn463
rkn463's Avatar
Need advice on steering wheel restoration
This will be for a stock 67 wheel. Mine, like almost all of them, is cracked from age and heat. I have seen several threads here and elsewhere of people repairing them. Some use bondo some use expoxies of various types. I am curious who has done this, what filler you used and if you are happy with the degree of difficulty, results and have you had any problems with it since. Also does anyone repop the CST center cap? Or even the plain cap, I have 4 of these wheels and the caps are terribly pitted on all of them.
Thanks in advance,
Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 02-26-2012, 01:39 PM   #2
jocko
jocko's Avatar
Re: Need advice on steering wheel restoration
I have used Eastwood's kit and was pretty happy with it. If I recall correctly, the 67 wheel doesn't have any textrue (pebbly lookin sections) on it, so the repair should be straightforward. My 66's wheel has some cracks in the textured area, and I believe it's gonna be a bear to duplicate it, but sill give it a shot eventually. Anyway, that's the direction I'd go. Especially since you have 4 wheels - you can repair them all, use the best, sell the other 3 and possibly break even (i.e. the Eastwood kit has enough material to repair several wheels).
Different Eastwood kit options on this page:
http://search.eastwood.com/search?w=steering+wheel
As for the horn button, I couldn't finad any at LMC, Brothers, or Classic Industries... Sorry.
Old 02-26-2012, 06:19 PM   #3
rkn463
rkn463's Avatar
Thanks for the heads up on the Eastwood kit. I had never run across that before. My attempts at finding a reproduction center cap have all turned up nothing as well. Thanks for checking!
-Richard
Old 02-26-2012, 07:43 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is a how to from a member that is no longer with us:
http://www.67-72chevytrucks.com/vboa...d.php?t=233643
_RIP ESLL_
LockDoc
Leon
Old 02-26-2012, 09:20 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I repaired my wheel in my 68.I wasn't going for show looks just decent to drive.I first cleaned the wheel with some steel wool.Then I filed/ground out the cracks.I filled them with an epoxy from an industrial supply(IIRC it was a 5 min version),I tried to keep the epoxy level to the surface since it's probably gonna be harder then the wheel plastic.I filed/sanded it smooth.Since I was repainting the interior to gray(from Fawn/sandewood) I again cleaned it well with steel wool and hung it up from the center.I used brake cleaner but would hhave used paint thinner or mineral spirits if I had of had it on hand.Once I was sure it was dry(I left it overnight) I sprayed a mist coat and cover coat of rustoleum.The next day I hung it the oposite side up and did the same.The I wrapped it with an old school leather wrap.It's been painted like that for about 8-10 years and looks like it did the day I reinstalled it.I did get lucky and find a standard original horn button at a swap meet.My interior is getting just rough enough that I may respray it again soon and I'll probably redo the paint and wrap on the wheel.I don't daily drive it now but did for at least the first two years after I repaired it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-27-2012, 03:46 AM   #6
oldspowered67C10
Ive restored them before using both epoxy and body filler. The epoxy is super strong but takes awhile to set up and sands slowly. The body filler sands fast and is easier to form when applying but I dont trust it for structural stuff. If I was building a completely missing section Id use epoxy but for cracks and small splits Id use body filler.
oldspowered67C10 is offline   Reply With Quote
Old 02-27-2012, 09:16 PM   #7
rkn463
rkn463's Avatar
The difficulty of sanding the epoxy is exactly what had me concerned. None of the cracks are huge so I think I'll give the bondo a whirl first. If it cracks again I could always grind it out larger and refill with epoxy later.
As always, thanks one and all who have replied. This site rocks!
-Richard
