Old 05-01-2003, 11:06 PM   #1
imdarren
imdarren's Avatar
Engine Castng # Help.
I'm looking at buying a good running small block for $150.
Could someone please tell me datails about this motor (4 bolt, year etc).
I looked at the Mortec site and couldn't see any number that seemed to mach even close . . . .
Two sets of numbers.
Smaller size numbers T4Z504005
Bigger size numbers V0921TJB
Thanks.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 05-01-2003, 11:13 PM   #2
jacquesdean
re: block ident
Darren, on the right side of the distributor at the rear of the block is a 7 digit number eg: 3970014, 3970010.
this is the number you want. It will tell you what year it was from and what cars or trucks it was install in.
I have a book that will tell . let me know and i'll look it up.
Jock,
Powder blasting shop, Alabama
jacquesdean is offline   Reply With Quote
Old 05-01-2003, 11:15 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
its a a 350 and it could be from a 1973 c10 2500 or 79 c30 or 3500 both are rated at 160-165 hp
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 05-01-2003, 11:17 PM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
This was just discussed a few days ago. http://67-72chevytrucks.com/vboard/s...threadid=50764 Go here- http://www.teufert.net/sbchevy/sbchevy.htm I think it's a '79 350, so I'd start there. Search until you find TJB, and it'll tell you the info.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-01-2003, 11:26 PM   #5
imdarren
imdarren's Avatar
I realized I gave the wrong numbers. I'll have to call the guy back, and get the numbers off the rear of the motor.
Thanks jacquesdean.
Thanks for the help guys.
darren
Washington State
Old 05-02-2003, 12:23 AM   #6
Rod
Those 3070010 and 3970014 will only give you so much info over a board range of years.
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
3970014....350...70-76...2 or 4
The Suffix TJB is more helpful in determing what year and motor you have.
1973 TJB 350 conv.cab 160HP 4BBl C0 to 2500
1979 TJB 350 frwd cab, a/t L LS9 165HP C-30 & 3500
Some of the Engine Suffix letter code combinations were used a number of times. For example, in 1974 the suffix code "CMR" was used on three different vehicle models with the same engine and transmission combinations. "CMR" was again used in '78 with a Corvette and a different engine/transmission combination. You would need to look at the block casting date to know which year the block was made to narrow down the possibilities. Relying solely on the suffix code to identify the original use of the block can be misleading. You need to look at ALL of the casting identifiers before making your determination.
Those smaller numbers you read in the same pad area at front passenger head is part of the serial number of the vehicle it came out of. GM stamped those in some years also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-02-2003, 06:54 AM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
I agree, Rod. You must look at all of the numbers. I just had the same problem trying to figure out what engine was in the truck I bought. Between the addy's I sent and the other info you've received, finding out what the block actually came from should be (somewhat) easy. We're always here, though......
Old 05-02-2003, 11:04 PM   #8
imdarren
imdarren's Avatar
Here are more numbers. (To go along with the ones I posted at the top of the thread)
3970010
# by Distributer is 1173 (Year?)
I'm told it is a 350. And I belive it is.
Any more details / info would be helpful.
Thanks!
Darren
Washington State
Old 05-02-2003, 11:31 PM   #9
jmanz69
Careful, they attack...
jmanz69's Avatar
Here is the info I have on it.
3970010 68 - 79 350 & 327, 145-375, 2&4-Bolt mains Truck/Hi Perf
jmanz69 is offline   Reply With Quote
