Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-26-2012, 04:23 PM   #1
Blue Rat
How many run windage trays?
I have one I can install, but do not know if it is needed or not. Do you run them? Do they make HP or cost us HP or just no effect?
Blue Rat is offline   Reply With Quote
Old 02-26-2012, 06:07 PM   #2
Blue Rat
Re: How many run windage trays?
Well after searching several forums have decided this has been beat to death. I do not think I am going to run it.
Old 02-27-2012, 12:43 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
A widage tray is a definate plus to help strip the oil that wants to rope around the crank. It is lost HP for sure. But if you don't hve some place for that oil to go,, it has marginal effects. A pan that offers someplace for that oil to return to the pan that packs up against the passengers side pan rail will return WAY mor HP than just a windage tray for sure.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-27-2012, 11:31 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I have run them on the last 3 motors . DOnt know if they work or not .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-27-2012, 08:52 PM   #5
Blue Rat
I have the seven quart Milidon pan. Still on the fence on the tray?
Old 02-27-2012, 10:17 PM   #6
raceman6135
Dino burner
raceman6135's Avatar
I run trays in conjunction with scrapers. They have proven to be worth a couple of horsepower when running a stock 4-quart pan on my big block Chevrolets.
More importantly, though, they help keep more of the oil in the sump where it can be picked up by the pump, as compared to not having a tray and scraper.
raceman6135 is offline   Reply With Quote
Old 03-04-2012, 02:21 PM   #7
bigsnookmaster
bigsnookmaster's Avatar
I run a scraper and windage tray also.
bigsnookmaster is offline   Reply With Quote
Old 03-04-2012, 10:35 PM   #8
moggey01
Big pans help, on all the aluminum pans I have messed with we left the screen in. Some people think its better without them, but we have had great luck with them.
moggey01 is offline   Reply With Quote
