Old 02-26-2012, 05:33 PM   #1
itstheshu
blinker trouble
I need some help with the blinkers on my 54. I am in the process of installing a Ez21 harness and I am testing as I go. I wired the blinkers and brakes lights and I can get them to come on but the blinkers do not blink. Any help would be great. Thank you. Josh
itstheshu is offline   Reply With Quote
Old 02-26-2012, 05:53 PM   #2
youngrodder
youngrodder's Avatar
Re: blinker trouble
I take it that you have a flasher hooked up in your fuse panel? Also if you are using any type of LED light they require a different flasher. Also did you try it with your iginition on?
Just thinking out loud.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-26-2012, 10:30 PM   #3
itstheshu
Re: blinker trouble
I am using the flasher in the fuse panel. I got it to work if I put more draw on it. I think I need to get a different flasher.
Old 02-26-2012, 10:31 PM   #4
itstheshu
Re: blinker trouble
Thank you Marc
Old 02-26-2012, 11:09 PM   #5
mr48chev
mr48chev's Avatar
Re: blinker trouble
You will need one something like this one. http://www.ebay.com/itm/Flasher-Led-...item2ebbd5a259
You should be able to get it locally but the prices I have seen can be pretty stiff on them.
Old 02-27-2012, 12:41 PM   #6
itstheshu
Re: blinker trouble
The thing is I dont have led lights. I plan on upgrading down the road but have lights with 1157 bulbs in the back and the stock marker lights in the front.
Old 02-27-2012, 03:27 PM   #7
_Ogre
_Ogre's Avatar
Re: blinker trouble
i think your flasher is bad. the ezwire 21 has 2 flashers for blinkers and 4ways. swap them out.
i have led rear lites but standard bulbs up front, this was enough load to activate them.
shop air compressor timer
