02-26-2012, 08:07 PM | #1 |
Kind of embarassing...need a part number
So I looked around a bit and apparently I was looking in the wrong places. I tried around town with no luck to I went to order online.
Its easy right? Wheel bearings for 1969 C-10 2wd SWB I6 engine standard size brakes. Does anyone have a Timken (or whomever) part number for the bearings, races, and seals? Thank you in advance. Hope this is posted in the right section.
That's Medium Gold. You just want to see Ochre. |
02-26-2012, 08:12 PM | #2 |
Re: Kind of embarassing...need a part number
heres a start
http://www.rockauto.com/catalog/x,ca...,parttype,1672
Trueman |
02-26-2012, 08:34 PM | #3 |
Well, I already went there.
It is kind of confusing to me. Usually I am good with RockAuto but not this time. I dont know if I need 2 different numbers for the bearings or 4 of the same ones. Im getting different signals everywhere I go.
02-26-2012, 08:54 PM | #4 |
If i remember right there is two sizes the inner and the outer.
If all else fails you could pull a wheel and get a number off the bearing. Iam sure some one will chime in.
Trueman |
02-27-2012, 07:54 PM | #5 |
AutoZone pulled through thankfully.
Timken numbers: Inner Bearing-SET2 Outer Bearing- SET5 Races-RACE2 Seal-9015S
