Old 02-26-2012, 09:43 PM   #1
Rubble
Rear spring hangers
I am in the process of converting a 1987 1 ton 4x4 dually to a single rear wheel.This truck had Dana 60 in front & 70 rear. Axle ratio was 4:56. This truck has a 6.2 with TH400,I didn't need that heavy of a diff and wanted a higher speed axle as this truck won't be used to tow anything.When I went to mount the semi float 14 bolt in rear I found spring perches about 1" too wide on either side. I measured the hangers on my 86 3/4 ton 4x4 and they are about 1" wider. I took a set of hangers off a parts truck so axle will fit ok now. Just wondering if this is common?This truck was seen lots of changes before I got it so anything is possible.thanx
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 02-26-2012, 11:32 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Rear spring hangers
Yes all 1 tons have narrower spring width in order to run dual wheels and not rub the springs.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-27-2012, 12:05 AM   #3
Rubble
Ok,thanx.The build sheet in glove box says this truck was originally a 2wd single rear wheels,but the hangers may have been changed because the rivets had been replaced with bolts.
