Old 05-02-2003, 01:08 AM   #1
crazy4chevs
crazy4chevs's Avatar
help! need exploded veiw of tilt column I cant get it apart
has anybody taken one apart? I cant get the tilt section off the column so i can redo it. Ive got the upper berings out and the tilt tension spring out, and cant see anything else that would hold it.
If you have pics, know how, or have any sugestions I sure could use them.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 05-02-2003, 01:14 AM   #2
alta-aj
I'd like one too.
alta-aj is offline   Reply With Quote
Old 05-02-2003, 04:06 AM   #3
Southpa
Southpa's Avatar
Theres about 4 different GM tool # J-XXXX that instructions recommend using for pulling these suckers apart. Just gotta wing it. Heres an exploded tilt. Good luck!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 05-02-2003, 04:10 AM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
Thanks for the pic
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 05-02-2003, 10:53 AM   #5
crazy4chevs
Thanks for the pic, southpa
So it looks like its the cover that i cant get off. After that i should be able to pull the side pins and have it apart.
Anyone know how to get the cover off without wrecking it? Does it slide off? unscrew? or what.
And thanks for the Help again!
Old 05-02-2003, 11:20 AM   #6
JimKshortstep4x4
Talking
I use a small screwdriver and hammer to tap the cover off. You will want to go around the cover to move it uniformally so as not to cock it. Penetrant will help it slide off easier as it is just a slight press fit.
Here is a pic.
Jim
Old 05-02-2003, 11:39 AM   #7
crazy4chevs
Thanks jim, now I can actually get somthing done. Havent done much in the last two months
Old 05-20-2003, 03:11 PM   #8
greenhorn male
greenhorn male's Avatar
disassembling tilt column
After removing the cover and driving out the 2" pin that I beleive holds in the tilt steps or shoe, what's next?
I like to dissasemble my tilt column completely. With the 2" pin out
everything is still tight in place. Could someone get me to where everything is visibly self explanatory, then I'll take it from there. Thanks,
Luis
greenhorn male is offline   Reply With Quote
Old 05-20-2003, 06:35 PM   #9
crazy4chevs
That pin is a pain in the @ss to get back in after you get it apart.
If I had to do it again I would leave the 2" pin in. Pull the side pins and then pullback on the tilt lever to release and they should seperate.
Old 05-20-2003, 08:41 PM   #10
greenhorn male
Yes, I know ...but I'll worry about that after I get the right pivot pin out. My slide hammer isn't budging it a bit. Someone must have installed it with JB weld. The screw broke in the hole and i've broken 3 drill bits already trying to tap it out. I'm getting close to getting the sledge hammer out
