Old 02-27-2012, 12:13 AM   #1
c6_rob
c6_rob's Avatar
350 / 700r4 Combo - Firewall mod needed?
Hello All,
So with the help of you all Im putting together my drivetrain. My 3.42 rear is ready. 700r4 sitting on my floor. Still working on my small block.
Im probably going to go with a No Limit front IFS.
For those of you that have dropped in a 350SB with a 700r4 or TH350 trans, did you have to modify the firewall for clearance? If so how much? What IFS if any did you use?
I just want a heads up of what im in for.
Pictures??
Thanks in advance
52 Chevy 3100
c6_rob is offline   Reply With Quote
Old 02-27-2012, 01:18 AM   #2
parkwood
parkwood's Avatar
Re: 350 / 700r4 Combo - Firewall mod needed?
I didn't get what year truck you are working on so the first two pictures are from a '56 chevy with a 350/700r4 and no work had to be done to the fire wall, the last two are from a '52 suburban with a 350/700r4 and we had to open the top up a little to clear the top of the trans.... hope this helps..
parkwood is offline   Reply With Quote
Old 02-27-2012, 02:54 AM   #3
G&R's57GMC
G&R's57GMC's Avatar
If your working on a 55-59 you shouldn't have to modify the firewall or floor to get a small block and 700r4 mounted. If you want to set the engine bake as far as posable use a small distributor instead of the HEI.
I'm using a 5.3 Vortec and 4L60E in my '57.
BTW I used No Limit Wide Ride Front suspension and their Fat Bar Rear suspension.
G&R's57GMC is offline   Reply With Quote
Old 02-27-2012, 04:03 PM   #4
_Ogre
_Ogre's Avatar
he has a 52 chevy 3100 in his signature
no fire wall mod required and if you use an ifs you can center the motor too
fatman has imo the best ifs for these trucks.
shop air compressor timer
Old 02-27-2012, 05:52 PM   #5
G&R's57GMC
G&R's57GMC's Avatar
Hi Oger,
Gee did I miss something in C6_ROB's Signature ? All I see is Corvettes !
So since he didn't mention what he was working on I put in my 2 cents assuming he might have a TF.
So I just went back and dug through his profile to find his sig, sure enough there it was. Sure would have saved the confusion if he mentioned what he was working on or showed below his pic.
Old 02-27-2012, 07:00 PM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
You should not have to touch your firewall. This is 1954 truck with a small block, 700r4 and Nova clip and the firewall was not touched.
Kabwe is offline   Reply With Quote
Old 02-28-2012, 12:36 AM   #7
c6_rob
c6_rob's Avatar
Originally Posted by Kabwe View Post
You should have to touch your firewall. This is 1954 truck with a small block, 700r4 and Nova clip and the firewall was not touched.
Thats a great pic. Thanks for the info guys, it really helps.
BTW yes I should have specified what I truck I was referring to. 52 3100. Im on a few Corvette forums so to keep it simple I use the same name and avatar. Much less to remember!!
52 Chevy 3100
Old 02-28-2012, 04:01 AM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
I meant to say that you should not have to touch the firewall.
Old 02-28-2012, 11:34 AM   #9
mr48chev
mr48chev's Avatar
You don't if you set the engine as Kabwe did. I've seen several though that the guys wanted to mount the engine higher in the engine compartment and ran into trouble at the firewall and floorboards.
At one time I had a 350 with a turbo 400 behind it in the 48 with no floorboard or firewall modifications.
Usually it works better to mount the trans first and then level the engine and put in the front mounts. That way you can get the floorboard clearance you want and get the output shaft of the trans where you want it and not fight the firewall or floorboard.
Old 02-28-2012, 07:48 PM   #10
Clay54
Originally Posted by c6_rob View Post
Hello All,
Pictures??
Thanks in advance
C6_rob, in 1968, I bought a '54 and it had a '49 Cadillac engine and a 4 speed hydromatic. In 1975, I changed all that out for a 327/TH400. It does not have a modified firewall nor does it have a hump in the floor. Also used the original radiator. Good luck with your build. Clay
Clay54 is offline   Reply With Quote
Old 02-28-2012, 11:56 PM   #11
_Ogre
_Ogre's Avatar
i'd touch that firewall, that's sexy gGRRrrr
G&R the signature is the last line of the post, repeated in every post as a signature
just like the post above this and all of clay54's posts have:
54 Chevy 5 window/89 S10 swap(not yet started)
84 Chevy Suburban 6.2 diesel
04 Chevy Crew cab long bed Duramax
at the bottom and all of my posts have:
cool, an ogre smiley ogre's 58 truk... ogre's interior build
if necessity is the mother of invention, poverty is the mother of necessity - plato
you can set up a signature in your control panel under signature, don't be such a grump
Old 02-29-2012, 12:55 AM   #12
solidaxel
solidaxel's Avatar
My 53 has a 4L60E and my 55 1st has a Tremac and I did not remove any firewall or floor sheet metal to install this combo, and I still have room to remove the valve covers
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
