02-27-2012, 05:38 AM | #1 |
Diggin The SquareLife
gauge cluster bulbs
gona upgrade my gauges soon an need to know what bulb size are in the gauge cluster an how many there are...gona replace them too...thanks.
02-27-2012, 11:50 AM | #2 |
Re: gauge cluster bulbs
They have 194 bulbs stock.
The 168 bulb is a direct replacement and are brighter. I can't remember how many there are, sorry One thing you can do to brighten the cluster up is paint the inside of the back piece white. I did that on my '80. It helped immensely!!! Posted via Mobile Device
CHEVY ONLY |
02-27-2012, 12:17 PM | #3 |
When I changed my bulbs I also changed the warning light bulbs too. I think there was 10 total.
John 82 Chevy Silverado 350ci/TH350 |
02-27-2012, 12:18 PM | #4 |
Slots go on anything!
I think there are 8 or 9 bulbs in there. I bought a box of 10 at Napa when I did mine, and sis not use them all. I also didn't replace the warning light bulbs, turn signal, high beam, etc.
1974 Jimmy- 5.3/4L80e/NP241 |
02-27-2012, 01:44 PM | #5 |
In the Forgotten far North.
Depends on the year really. My 90 suburban has/had 12 total originally.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-27-2012, 02:21 PM | #6 |
thanks for all the info guys!!!!
02-27-2012, 10:27 PM | #7 |
78K & 79C Jimmys
paint is a big plus,white can still be dimmed
i also added a second colour....red leds in the 78 wired to be on when the truck is running or can be switched off and just did the 79 in green,not in Leds tho,can be dimmed white and green are the regular bulbs,both with painted clusters, only the red is LEDs and no they don't dim
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 02-27-2012 at 11:09 PM. |
02-27-2012, 10:50 PM | #8 |
THATS BADASS!! thanks for posting...im goin to order gauge overlays in brushed aluminum an do blue leds!
02-27-2012, 11:03 PM | #9 |
Keep in mind the LEDs won't dim with the factory headlight dimmer switch.
I'll go find pics of my white painted cluster and 168 bulbs... Here are some pics http://67-72chevytrucks.com/vboard/s...&postcount=212 And some before and after shots http://67-72chevytrucks.com/vboard/s...&postcount=217 Posted via Mobile Device
CHEVY ONLY Last edited by joe231; 02-27-2012 at 11:13 PM. |
02-27-2012, 11:24 PM | #10 |
The do dim just not like a bulb
Posted via Mobile Device |
02-28-2012, 01:21 AM | #11 |
Huh?
CHEVY ONLY |
02-28-2012, 02:16 AM | #12 | |
02-28-2012, 02:53 AM | #13 | |
It turned out to give kind of a halo effect. Dunno, I dug it.... Posted via Mobile Device
CHEVY ONLY |
02-28-2012, 08:31 AM | #14 |
78K & 79C Jimmys
i had white over spray kinda mist the front
so i taped off the back with 2" scotch and sprayed it semi gloss front these are the bulbs i used ....have lots for my burbs "Christmas lights" http://www.toucanindustries.com/clie...ALOG(2of2).pdf
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-28-2012, 12:05 PM | #15 |
GM Addicted
Are those OG light bars or did you make them i also have one in my truck looking to add a dual channel one and a vibrasonic
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
02-28-2012, 12:10 PM | #16 |
78K & 79C Jimmys
me? those were made with the truck, custom
02-28-2012, 12:32 PM | #17 |
Those lights and wood are part of an aftermarket conversion.
I had a '88 Burb that was a Mark IV conversion. Had custom wood and lights everywhere. As far as I know, the conversion companies got/get brand new vehicles and convert them before they are sold to the public. Posted via Mobile Device
CHEVY ONLY |
02-28-2012, 12:35 PM | #18 |
GM Addicted
they dont say bowman or any brand on them at all. I will get a video tonight of the way mine looks
02-28-2012, 05:26 PM | #19 | |
78K & 79C Jimmys
still laugh about the rpo YG4 "rear seats not desired" gets no 2nd row seat belts,and no belts for the third seat
02-29-2012, 02:00 AM | #20 |
So are the LEDs just a straight swap or does anything need to be changes?
02-29-2012, 08:26 AM | #21 |
78K & 79C Jimmys
they look to plug right in
