Old 02-27-2012, 06:05 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
WEIAND 8004 Action Plus Intake Manifold SBC
I purchased this to run on my K5 but never used it. $80 plus actual shipping. Description from the internet...
Weiand Action+Plus intake manifolds are designed for use as stock replacements, with improved power and torque characteristics. They're 180 degree, dual plane types, with a carburetor flange that'll accept either stock or aftermarket performance carburetors. Their effective rpm range runs from idle to 6,000 rpm. With their high-flow runner design, and ability to produce increased power with little modification, it's no wonder these manifolds are so popular.
Intake Style: Dual plane
Basic Operating RPM Range: Idle-6,000
Intake Material: Aluminum
EGR: No
Notes: HEI will clear.
*** I can have this sandblasted and powder coated locally before shipping. Probably $40 but I would have to check on the cost.... I think the also do ceramic coating (not Jet Hot, but ceramic powder)
Rich
1972 K5 Blazer CST Click HERE
Old 03-02-2012, 02:12 AM   #2
mcmlxix
mcmlxix's Avatar
Re: WEIAND 8004 Action Plus Intake Manifold SBC
Price Lowered - $80 plus actual shipping...
I will need to find a box....
Rich
Old 03-02-2012, 02:49 AM   #3
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Nice informative thread. How do you think these would compare to the 2701 rpm Edlebrock intake??? If it is still available here in a few.. I might take er'...
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 03-02-2012, 03:01 AM   #4
mcmlxix
mcmlxix's Avatar
Looks like they're both dual plane with the Weiand having a slightly higher RMP range. I would guess they are close enough that it would be hard to notice a difference... It would depend if you needed the extra RPMs...
Rich
Old 03-16-2012, 02:44 AM   #5
mcmlxix
mcmlxix's Avatar
ttt.... remember, I can have this custom powder coated any color....
Rich
Old 04-05-2012, 04:57 AM   #6
mcmlxix
mcmlxix's Avatar
How about a ceramic coating??? black or silver....
Rich
Old 06-01-2012, 05:33 AM   #7
mcmlxix
mcmlxix's Avatar
... but I am going out of town till the June 9th...
Rich
Old 06-29-2012, 04:13 AM   #8
mcmlxix
mcmlxix's Avatar
bump
Rich
Old 08-16-2012, 06:17 AM   #9
mcmlxix
mcmlxix's Avatar
Bump.... I have a spread bore carb for the manifold that I could throw in for $60....
Rich
Old 08-18-2012, 12:59 AM   #10
unclesalty
unclesalty's Avatar
if you still have this.... Im wondering what type of choke pull off its set up for, it looks like maybe the angled hot air tube, or is it the flat (level w/ the street) bi metal spring found on the early factory spreadbore manifolds, like the '69s? how much to ship to 48609?
unclesalty is offline   Reply With Quote
Old 08-18-2012, 01:21 AM   #11
unclesalty
unclesalty's Avatar
refering to the flat boss cast between the center two (intake manifold to cylinder head) bolt holes, in your first photo it sits directly centered under the carburator flange. You may not even have a need for the choke in AZ, but up here we got to have em.
Old 08-18-2012, 01:24 AM   #12
unclesalty
unclesalty's Avatar
what kind of carb do you have, a quadra jet? do you have the numbers? is it a 4mv, divorced choke or an electric etc? pics?
Old 08-19-2012, 09:48 PM   #13
unclesalty
unclesalty's Avatar
Picked up an edelbrock, thanks anyhoo
Old 09-15-2012, 03:05 AM   #14
mcmlxix
mcmlxix's Avatar
bump to sell....
Rich
Old 10-17-2012, 04:46 AM   #15
mcmlxix
mcmlxix's Avatar
started my LSx swap .... bump
Rich
Old 01-05-2013, 06:37 AM   #16
mcmlxix
mcmlxix's Avatar
ttt
Rich
Old 01-23-2013, 01:37 AM   #17
mcmlxix
mcmlxix's Avatar
I can sand blast this for free..... if you're not in a huge hurry....
Rich
Old 03-07-2013, 04:49 AM   #18
mcmlxix
mcmlxix's Avatar
Some one buy me... I need a block to hold on to ....
Rich
Old 10-05-2013, 02:53 AM   #19
mcmlxix
mcmlxix's Avatar
Bump
Rich
Old 01-28-2014, 10:53 AM   #20
bondo510
Did it ever sell?
bondo510 is offline   Reply With Quote
Old 01-28-2014, 06:09 PM   #21
mcmlxix
mcmlxix's Avatar
Originally Posted by bondo510 View Post
Did it ever sell?
No, I stashed it on a shelf... If you're interested I need to find a box for shipping....
Rich
Old 02-11-2014, 08:29 AM   #22
bondo510
What's the best you can do shipped to 95368? Thanks
