Old 02-27-2012, 04:18 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
front end
i need to find out what can i do to fix the bounce i get from my truck.
i have a stock crossmember. ss 7 bags and cpp shocks. i did buy but havent installed the shock replacement. the only thing i can think of is that the shocks are no good? and if so i guess i need to some KYB
Sick5 is offline   Reply With Quote
Old 02-27-2012, 04:24 PM   #2
SevenOne
SevenOne's Avatar
Re: front end
Does having less or more air in your bags help lessen the bounce any?What psi are u at when riding?
SevenOne is offline   Reply With Quote
Old 02-27-2012, 04:37 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: front end
well a bit.. i dont complaine but the wife says that truck gives breast cancer
i dont run gauges.. but im thimnking of running some soon!
Old 02-29-2012, 03:13 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
Re: front end
gauges with air suspension is necessary, adjustable shocks may also help.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 02-29-2012, 11:13 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front end
With out gauges you can't possibly fix your issues unless you enjoy swapping parts. My guess is your bag pressure is no optimized, but we won't know till you get gauges.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-29-2012, 11:17 AM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: front end
Do I need a gauge for each corner
Old 02-29-2012, 11:56 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front end
No, but it would help. Tell us more about your system please. how many valves are you running? What does this refer to? "i did buy but havent installed the shock replacement."
Articles-
"Refining Sierra"
Old 02-29-2012, 04:05 PM   #8
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: front end
Ready!
i have 8 valves
running 7 gal tank
1/2 inch lines
and what i meant about the "shock replacement" are the upper shock mount.sorry!
i bought a pair of them from a buddy of mine. not sure if the will help. but i do have them
Old 02-29-2012, 08:37 PM   #9
tubbedII
needs more $$$
tubbedII's Avatar
Re: front end
Gauges usually have dual needles, so 1 gauge will handle 2 bags, so you should get 2 gauges. You'll also need to figure out where to plumb into your lines to get the pressure reading.
You don't "need" them, but it would help knowing you're setting the ride height the same each time for both alignment and ride quality (once you find the quality spot that is). Have you tried riding around with more or less air in the bags and did it make a difference? About how high are you lifting truck from full drop? Most bags want to be between 6-9 inches tall inflated for a good ride...are you in that range?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-01-2012, 12:35 AM   #10
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: front end
its been awhile since i drove it. i just added the rear drop member and still working on the angle of the shaft. as soon as im drivable. i will post my info
Old 03-01-2012, 11:15 AM   #11
made2drag
made2drag's Avatar
Re: front end
dont shoot me for stating something obvious and judging by how modified your truck is you probably know this but...shocks have a sweet spot and if they are not running in the sweet spot they cant do their job right. the sweet spot is usually the 2 inches of travel in the middle of the stroke. pull the shock out all the way then compress it back half way and its in its sweet spot and you could re-do your upper mount
made2drag is offline   Reply With Quote
Old 03-01-2012, 11:26 PM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: front end
thanks for the info.
