Old 02-27-2012, 09:37 PM   #1
chris91
vortec distributor
Is it possible to use one of the crab type distributors on a gen 1 engine. Is the length of the shaft or something different.
chris91 is offline   Reply With Quote
Old 02-27-2012, 09:51 PM   #2
hugger6933
Re: vortec distributor
The inside of the dist is basically a hall effect switch. The guts inside won't do you any good. It is basicly like a crank trigger setup for a race engine. There are no advances in there
hugger6933 is offline   Reply With Quote
Old 02-28-2012, 01:42 AM   #3
Captainfab
60-66 Nut
Yes it will fit. However as hugger6933 mentioned, that distributor won't do you any good without the PCM and all the sensors to make it all work.
