Old 02-28-2012, 06:36 AM   #1
Kerlijah
Kerlijah's Avatar
Question Candy paint...anybody out there used it?
So I'm gonna be painting my '79 this summer, and I'm thinking about using Duplicolor Candy Apple Green, with candy black and silver...anybody used Duplicolor candy paint before? Is it any good? If anybody's got pictures of candy painted trucks, especially of the candy green, feel free to throw em up here, it'd really help me out!!
Here's a quick draft rendering of the truck...and the colors I want to use...what do yall think?
~Wooden Indian~
1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun!
Kerlijah is offline   Reply With Quote
Old 02-28-2012, 11:51 AM   #2
terryj
Re: Candy paint...anybody out there used it?
I know of a couple of guys here that have use House of Kolor paint with very good results, don't know about Duplicolor. Candy paints can be real tricky, it all depends on your base coat as to how the candy turns out. If you never used candy paints before I'd suggest you gather all the info you can and use only good quality paint, if not it can be a very expensive lesson.
Heres a link to House of Kolor: http://www.houseofkolor.com/index.jsp
terryj is offline   Reply With Quote
Old 02-28-2012, 12:16 PM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Here's a better link: http://www.tcpglobal.com/HokPaint/
I've never heard anything bad about anything from TCP Global, including the HOK stuff.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-28-2012, 12:32 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
my 79 is green
don't know the green but PO called it like a "candy apple green"
anybody know it?
not even close to your choice tho......nice choice
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-28-2012, 02:06 PM   #5
jhngardner367
jhngardner367's Avatar
I've used the Duplicolor,and a few others.I heartily agree with Terryj. Candy colors must be mixed perfectly,the gun must be adjusted perfectly,air pressure exact,and surface prep/basecoat has to be flawless. It is very easy to get "tiger-striping",heavy spots,etc.,especially with larger areas. I would suggest a lot of practice,first,and use an HVLP gun,with air pressure of 15-18 psi. Prime and base coats should be finish sanded with 1000-2000 grit,and thoroughly cleaned with prep-sol,before candy is applied.When candy paint is mixed,it should be done in a clear jar.It will look black,until the jar is tipped ,slightly,at which time it should show the true final color. Each coat will not only deepen the tone,but will also magnify any goofs. PRACTICE,PRACTICE,PRACTICE! I've done auto painting for several years,and candy is still a tough job.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 02-28-2012, 04:14 PM   #6
Kerlijah
Kerlijah's Avatar
Awesome, thanks for the great advice guys! I've got a buddy helpin me build my truck, he'll be painting it for me. He's painted something like 300 cars in the last 15-20 years, and is a total whiz kid when it comes to this stuff. His work always looks amazing, so I'm not too worried about him messing stuff up...however, I dont know for sure if he's ever actually used candy paint. I'll definitely be doing a LOT of research before we get too hot and heavy on the paint!
Would yall suggest maybe just using a metallic paint (or something else?) instead of candy? Would that be safer/easier? I'm on a shoestring budget here, so if I can avoid having to paint stuff twice to fix mistakes, that's what I wanna shoot for, lol
~Wooden Indian~
Old 02-28-2012, 04:30 PM   #7
jhngardner367
Your friend has probably used candy colors,then.If so,he shouldn't have a problem.Ask him,to be safe,though.
Old 02-28-2012, 04:38 PM   #8
terryj
Metalics can be awesome paint jobs and are allot more forgiving than candies, all it takes is one mistake on a candy paint job to screw up the whole thing. There is no going back and touching up a candy paint job, because each layer makes for a different hue of color.
Old 02-28-2012, 06:55 PM   #9
Goldfinger
Goldfinger's Avatar
go metallics they are amazing for shine. Try to find a dupont carquest. dupont paints work well and last
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-28-2012, 11:31 PM   #10
BigMike608
BigMike608's Avatar
I've had candy paint jobs before on a few past vehicles and they look great until you have a fender bender or something. You will have to have the entire vehicle repainted because it so difficult to match the color back exactly
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 02-29-2012, 01:02 AM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
^^ that there raises a good point.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-29-2012, 08:22 AM   #12
78 Chevyrado
Ran across this thread the other day in the 60-66 section...
http://67-72chevytrucks.com/vboard/s...d.php?t=511170
78 Chevyrado is offline   Reply With Quote
Old 03-01-2012, 06:00 PM   #13
Kerlijah
Kerlijah's Avatar
Yall bring up some good points! Thanks for all the advice, I think I'll probably end up just going with a metallic paint instead of messing with candy. Gotta do some research and figure out what the best product would be for my budget...any suggestions?
~Wooden Indian~
Old 03-01-2012, 07:19 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
actually mine is metallic,granny smith green?lol
John
Old 03-01-2012, 07:52 PM   #15
Kerlijah
Kerlijah's Avatar
Haha granny smith green huh? I wonder who comes up with these color names...
~Wooden Indian~
Old 03-01-2012, 08:16 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
That's what I called it lol I duno what it really is
John
Old 03-01-2012, 08:41 PM   #17
Kerlijah
Kerlijah's Avatar
Haha oh! My bad, I thought you meant that was the actual name =P
~Wooden Indian~
Old 03-01-2012, 10:10 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
PO told me candy lol after seeing it "granny" seemed more fitting
I'm hopeing it gets above 0 C soon so i can wash it,
turn it into a milf green. lmao
John
Old 03-02-2012, 02:08 AM   #19
Kerlijah
Kerlijah's Avatar
ROFL!!!
~Wooden Indian~
Old 03-03-2012, 08:12 AM   #20
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Try This guys product out of Louisanna!!! www.allkandy.com
Tenn has some good projects on YouTube, also!!! As a matter of fact look at the two on the 65 chevy truck! That's me friend of 20 yrs truck and I also get a little shout out from him!!!
Smoke_Dog is offline   Reply With Quote
Old 03-04-2012, 12:14 AM   #21
rayfinseats
Powerblock TV just did a show on candy painting last weekend...
rayfinseats is offline   Reply With Quote
Old 03-04-2012, 12:22 AM   #22
smokedat
smokedat's Avatar
I painted a motorcycle with duplicolor base and their clear, thats what the costumoer supplied, the clear was a POS poor quality, but what do you expect for like 23 a quart, as for there candy i have no idea. U stated candy green and candy black and silver, there is no such thing as candy black or candy silver. The real way of achieving a candy coat is spraying a translucent coat over a silver or gold etc,
Depends on youre budget but if you want good results go with HOK they are the candy masters.
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 03-04-2012, 12:28 AM   #23
smokedat
smokedat's Avatar
found these pics forgot the name but its duplicolor white with their clear.
their clear is not the greatest it doesnt like to be stacked so you cant really color sand it best bet is to shoot it flat with no peel
Old 03-04-2012, 03:32 AM   #24
slinginrods
slinginrods's Avatar
I'll post some pics of a bike helmet I painted for my kid,it's all ppg .white base,then silver metallic ,then a candy purple,finally clear.she wanted a pony on it so I drew the pony right on the silver with a sharpie ,also masked the flame pattern then,shot a few coats of candy till I got the color I wanted.the more coats you apply the darker it will get.if you need to match it will be very difficult to do so,so it's not usually recommended on a daily driver.but youll get crazy cool points for the balls to run candy paint everyday.
slinginrods is offline   Reply With Quote
Old 03-04-2012, 07:08 PM   #25
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Metallic blue, Roth blue flake and Oriental Blue candy concentrate.....all HOK
Similar but with candy lace panels....
HOK silver, silver flake then blue and purple candies....
Green HOK candy over AutoAir green....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
