Raising the Rear/New Bed
I'm wanting to raise the rear of my 62 LWB a couple of inches. What's the best way to do this? Also, I picked up a new bed and tailgate, I've never disassembled one completely - will the sides and back come apart without cutting any welds?
Re: Raising the Rear/New Bed
Everything will unbolt except for the angle strips that are spot welded to the bedsides. The have to be cut or drilled off.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
60-66 Nut
![]() ![]() Join Date: Mar 2007
To raise the rear, you might look into a set of new springs. The original ones have likely sagged in nearly 50 years. I believe CPP or someone else offers a set that is for Suburbans and Panels that are designed for more weight.
As for the bed disassembly, on a fleetside, the rear sill is welded to the bedsides in 2 places on each side. Other than that, it is all bolted together.
