Old 02-28-2012, 02:58 PM   #1
woodworkerusa
Speedometer Cable
Question - Have 65 sb ss with 350 in front of 700R4 anyone know correct length of speedometer cable? Trying to keep everything neat as possible, dont want excessive cable curled up or in bind from being too long/short. Thanks
woodworkerusa is offline   Reply With Quote
Old 02-28-2012, 04:25 PM   #2
oldgoalie
Re: Speedometer Cable
Just put a longer cable in my 65. Got one from the local parts store for a 1969, 2wd with a T-400, about 83" long, worked great.
oldgoalie is offline   Reply With Quote
Old 02-28-2012, 05:39 PM   #3
forestb
forestb's Avatar
loker sells one that you can cut to fit. It's expensive though.
forestb is offline   Reply With Quote
Old 02-29-2012, 03:33 PM   #4
woodworkerusa
Thanks old goalie picked up speedo cable last night and its exactly what I needed.
Old 03-13-2012, 12:48 PM   #5
AngryPirate
AngryPirate's Avatar
Gonna hijack this thread a little bit since searching the forums for 'speedometer cable' led me to this and since it's related it may help others find this information.
So, does it matter if the transmission is different than what came with the vehicle when ordering a new speedo cable?
My speedo is the original 1961 but the transmission is now an auto 350.
Also, how much of the cable should be exposed on the dash end? Mine seems to have a lot, like 2" or so. Seems a bit long to me.
And one final question, how tricky is it to install the new speedo cable into the transmission end?
Thanks,
- AP
AngryPirate is offline   Reply With Quote
Old 03-13-2012, 03:00 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
Ok so installing the cable is just a matter of screwing the caps on the end of trans and speedometer, but you have issues with being even close to accurate, wheel, tire, transmission... go here for futher corrections, we have most info here, just not everything yet,
http://chevelleengineer.home.comcast...eer/speedo.htm
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-13-2012, 03:02 PM   #7
AngryPirate
Much appreciated Rich.
Old 03-13-2012, 07:32 PM   #8
brokenspoke
brokenspoke's Avatar
part number or application?
brokenspoke is offline   Reply With Quote
Old 03-13-2012, 09:02 PM   #9
oldgoalie
[QUOTE=brokenspoke;5249841]part number or application?[/QUOTE^
69 chev p/u 2wd with T-400
Old 06-25-2016, 06:56 PM   #10
64LBSS
Will that same cable work with a 700r4?
64LBSS is offline   Reply With Quote
Old 06-26-2016, 12:49 PM   #11
oldgoalie
Yes, should work just fine.
