02-28-2012, 05:16 PM | #1 |
bbadfred
One Piece Products window kit problem
I bout my OPP kit in 07 and they were installed in 08. The body shop that did them had problems with them fitting the windows without a gap in the glass to the window frame/seal. I finally got the truck back from paint in 09. I have the truck almost done and we tried to adjust them again and the problem is that the glass is not the same size as the window opening and does not fit snugly in the weather strip. Even loose it does not fit and appears to be cut wrong? Has anyone else had this problem?
02-28-2012, 06:17 PM | #2 | |
Re: One Piece Products window kit problem
i would call one piece products..or go online and send them a message..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
02-28-2012, 06:24 PM | #3 |
All one piece window kits are a pain in the AS# i got one from brothers and am already having to fix probelms. If i had it to do all over again i would stick with wing windows
02-28-2012, 06:35 PM | #4 |
bbadfred
I waited such a long time thinking we were doing something wrong(the installer was in touch with them at the time). I thought I had read something on the forum about glass not being cut right. When you adj the pass side where it fits in the felts to the front tight, theres a big gap at the back. If you center the glass its not weather sealed and barley inside the felts front ad back?
02-28-2012, 06:40 PM | #5 |
Haven't they made like 4-5 revisions in the past years on the OPP kit? Perhaps you got an early kit, that has since been updated drastically...
www.tomthetruck.blogspot.com <-- Aka build thread. |
02-28-2012, 06:43 PM | #6 |
bbadfred
02-28-2012, 07:28 PM | #7 |
Mine are the same gap at top think you have to knock in the top corner of the door i was told
02-28-2012, 08:16 PM | #8 |
They're all junk
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
02-29-2012, 01:08 PM | #9 |
bbadfred
02-29-2012, 02:09 PM | #10 |
Mine would roll all the way up until I put the felt in look on YouTube
Posted via Mobile Device |
