02-28-2012, 05:35 PM | #1 |
Can someone here do me a favor? I need a measurement
Anyone that has done a 7" or close drop in the rear, can you please measure from the top of the frame to the top of the axle housing? Mine is a 68 so anything close to that.
Thanks |
02-28-2012, 07:32 PM | #2 |
Gearhead
Re: Can someone here do me a favor? I need a measurement
I can get a measurement from my 72' when I get home, it has the ECE rear bag kit, so Im not sure the actual amount of drop at the pressure I usually run... but I will get you a ride height and the measurement you requested if it will help...
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
02-28-2012, 09:59 PM | #3 |
It would be about 1" or less between the axle & bottom of the frame (no c-notch) so add the height of the frame to that.
03-01-2012, 03:02 PM | #4 |
Cool. Thank you
Posted via Mobile Device |
