Old 02-28-2012, 07:08 PM   #1
Weasel Diesel
Stepside rear fender replacement question
My 86 SWB stepside has the fuel door on the driver's rear fender in the front. Replacement (aftermarket) fenders do not come with this in it,.. they come without. The manufacturer states that the fender can be custom cut to fit the door. The factory fender is stamped to recess the door... I'm not seeing how to do this. Is there an aftermarket type fuel neck that mounts to the fender that I can just cut out a hole and install? all help appreciated.
Weasel Diesel is offline   Reply With Quote
Old 02-28-2012, 08:15 PM   #2
76stepsidechevy
Re: Stepside rear fender replacement question
Did you buy a fender already? Ive been looking at a lot of stepside fenders lately after getting hit and it seems like 79-87 should have the recess for the square fuel door. 73-78 have a surface mounted filler, Just a chrome gas cap in plain sight.
76stepsidechevy is offline   Reply With Quote
Old 02-28-2012, 08:42 PM   #3
1LowToy
I'd check around for another vendor or find a clean original fender. Seems like it should be there. Last choice would be to have it cut out of the old one and welded back into the new fender.
1LowToy is offline   Reply With Quote
Old 02-29-2012, 08:39 AM   #4
Weasel Diesel
Yea, got the fender already. I'm going to look into a neck for the 73-78, like you said and see if that install wouldn't be alot easier. The current fender is so cancer laden in that area, the option to graf it over to the new fender so I'd have the door, really isn't an option for me.
Old 02-29-2012, 09:16 AM   #5
Greenlee
Greenlee's Avatar
I have been going through the same thing. I couldn't find the correct fender new and finally found a used one on Craigslist. The fuel filler assembly just screws in behind the fender if you can find one. I have everything now but the fuel filler hose. I tried a radiator hose, but it's a different diameter at the tank and at fuel door so I'm having trouble finding a hose that will fit.
Greenlee is offline   Reply With Quote
Old 02-29-2012, 02:42 PM   #6
Weasel Diesel
Greenlee.... Hose is no problem... go to the local Boat parts shop, and get marine fuel filler hose. Bends fairly well, and is bought by I.D. & feet off roll.
Old 02-29-2012, 03:15 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
I may have a fuel filler neck for 73-76 if you need one
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-29-2012, 03:25 PM   #8
Weasel Diesel
Thnx 88, still looking at a couple options.... I kinda like the looks of this..
Ya'll happen to know the fuel filler hose I.D. on he tank off hand?
