Radiator cooler lines
Im replacing the radiator in my wifes blazer.Do i need a special tool to remove the quick disconnect lines that go into the radiator for the trans and oil cooler?
BAD BOW-Silverado XST
Re: Radiator cooler lines
The oil cooler lines use a clip to hold the line in place. Just use a small pick to remove the clip. On my 96 Jimmy, the lines have screw in connections.
You are correct gchemist.The radiator came with a little tool to remove them but it was easier to use a small screwdriver.Took me pretty much all weekend.These s-10's are a pain to work on.I think my leak came from changing the air filter.You have to fight the the top of the air cleaner lid to change the filter and it rubs against the oil cooler line and thats where it was leaking.I think im going to look into a new air cleaner set up when its time to change the filter again.
blood type; Retumbo
I have had decent luck by tightening the big nit where the cooler mounts in the tank. the seal shrinks with age.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
I replaced my lines three years ago. Now they are starting to leak badly at the radiator. I'm so tempted to remove them. If braided steel lines were not so pricey, I would replace the lines.
